Post by headcoats on Aug 17, 2020 19:30:05 GMT 1
The needle keeps sticking, but if you tap the glass it will drop back ! The gauge works fine apart from this !
Tried grounding it a few times to swing the needle to try and loosen it up which worked to a certain degree but is there anything I can do to fix it
Post by headcoats on Aug 18, 2020 13:11:06 GMT 1
Ok , Keep tapping the glass then LOL
Post by midlifecrisisrd on Aug 18, 2020 13:23:45 GMT 1
Only way is to open it up
3 things it can be
1-the needle is rubbing, bend it to clear
2-it needs oiled, carefully oil it
3-the damping mechanism is knackered, new temp gauge please 🙁
Post by headcoats on Aug 18, 2020 15:19:56 GMT 1
Fook I had the tacho apart to fit a new face and never thought the temperature gauge would need looking at
stasky
Post by stasky on Aug 18, 2020 19:06:01 GMT 1
gub the internals and fit a small digital temp gauge,theres a write up on here somwhere how someone did it to a set of 4l0 clocks,ive just done a ypvs one,which was easier,as the temp gauge aint in the tacho,of course im not too bothered about originality ,but what i did want was an accurate measurement of my temp
Post by JonW on Aug 19, 2020 5:16:59 GMT 1
gub the internals and fit a small digital temp gauge,theres a write up on here somwhere how someone did it to a set of 4l0 clocks,ive just done a ypvs one,which was easier,as the temp gauge aint in the tacho,of course im not too bothered about originality ,but what i did want was an accurate measurement of my temp I expect it was me... info on the digi-in-lc-tacho on my 421 build, under bodywork i would think.
