Post by lolly on Aug 17, 2020 13:41:06 GMT 1
would any one have a picture of the sprocket side bearing set up ; inside and outside . I have replaced all three bearings (spacers are present) but there is still a bit of movement .
there is a spacer on the inside (inside the hub)of the sprocket bearing and i am wondering if that spacer should be on the outside . thanks in advance
Post by oldelsieboy on Aug 17, 2020 17:03:13 GMT 1
would any one have a picture of the sprocket side bearing set up ; inside and outside . I have replaced all three bearings (spacers are present) but there is still a bit of movement . there is a spacer on the inside (inside the hub)of the sprocket bearing and i am wondering if that spacer should be on the outside . thanks in advance The reducer/top hat spacer should be fitted to the inside of the cush drive side wheel bearing. There should be a double top hat spacer fitted to the bearing located in the cush drive. OEB
Post by lolly on Aug 17, 2020 17:34:01 GMT 1
cheers ; i have that one but is there another one that fits behind the metal dust cover ? item 47 part number 90387-157a2 , it is shown on the fowlers fische
Post by oldelsieboy on Aug 17, 2020 17:52:30 GMT 1
cheers ; i have that one but is there another one that fits behind the metal dust cover ? item 47 part number 90387-157a2 , it is shown on the fowlers fische Yes there is a spacer between the cush drive bearing and the swingarm, the dust cover is an interference fit onto the spacer. Or you could buy a stainless steel one piece spacer/dust cover from Nick Chambers OEB
Post by lolly on Aug 17, 2020 19:14:43 GMT 1
cheers , thats the one i am missing , i have the dust cover but not the spacer
