Post by lolly on Aug 15, 2020 19:24:24 GMT 1
I need to replace the rear wheel bearing that sits in the sprocket carrier ; my circlip pliers arent man enough to remove the circlip ; any suggestions on how to get the f#cker out
Post by flames on Aug 15, 2020 19:37:13 GMT 1
New circlip pliers?
I have removed with 2 nails, pair of pliers / grips and a wedge before. Cut the point off the nails and slot into circlip holes,fit a wood or metal wedge between them and pinch below it. Not the easiest technique but has worked for me a few times. Filing a grove in wood each side helps keep the nails a bit more stable. Pinch above the wedge for outer circlips.
Post by lolly on Aug 15, 2020 21:05:38 GMT 1
New circlip pliers? I have removed with 2 nails, pair of pliers / grips and a wedge before. Cut the point off the nails and slot into circlip holes,fit a wood or metal wedge between them and pinch below it. Not the easiest technique but has worked for me a few times. Filing a grove in wood each side helps keep the nails a bit more stable. Pinch above the wedge for outer circlips. sounds good , cheers
