Post by roblc350 on Aug 14, 2020 22:01:20 GMT 1
Anyone on here do this service
I Have a Few YPVS F2 Clip on handlebars that are slightly bent and need the above treatment must be worth saving as these cant be brought new anymore ( not that i can find )
Cheers
Post by jon on Aug 14, 2020 22:44:13 GMT 1
I did mine myself. Just ground the old ones off and welded on new bar.
Post by Tobyjugs on Aug 14, 2020 23:02:42 GMT 1
+1
22mm hydraulic pipe
Post by JonW on Aug 15, 2020 0:29:59 GMT 1
you can un tweak them if not bad using a bar, some heat and a big (rubber ones are good) mallet, but if bad just cut and reweld.
Post by bare on Aug 15, 2020 3:22:36 GMT 1
Use an Oxy /Acet Torch and these can be bent back to factory accuracy.. fairly easily.
Post by roblc350 on Aug 15, 2020 8:50:02 GMT 1
Any offers to do the job ?? dont have a welder / oxy / acet torch
Post by roblc350 on Aug 15, 2020 19:40:57 GMT 1
Post by donkeychomp on Aug 15, 2020 22:02:10 GMT 1
What diameter are the forks for your clip ons? I have a few knocking about.
Post by roblc350 on Aug 16, 2020 9:53:00 GMT 1
Hi Alex 35mm There the F2 type...not just a normal clip on
Rob
Post by donkeychomp on Aug 16, 2020 21:37:54 GMT 1
Ah sorry mate, not got anything like that.
Post by roblc350 on Aug 16, 2020 22:10:02 GMT 1
ok Cheers anyway mate
Rob
Post by flames on Aug 16, 2020 22:39:47 GMT 1
You could try heating with a gas torch or barbecue or similar. You just need a heat source. If they are hollow fill with sand first, will help prevent the risk of kinking. Where bouts in the country are you? Maybe if a manner is near you they could help if you are a bit unsure?
Post by roblc350 on Aug 17, 2020 16:04:26 GMT 1
The F2 bars have a plugged end just a Threaded hole for the bar end to screw into so would be impossible to fill them with sand..Tried a gas torch..didnt work These have now been sent away to be done
Cheers Rob
Post by midlifecrisisrd on Aug 22, 2020 12:44:39 GMT 1
I've done some cold
Old stanchion in the vice, clamped the handle bar on then a 4ft pole on the end to "tweak"
I had 3 pairs and most had no sign of crash damage but all faced slightly different directions
Made a jig out of blocks of wood with straight lines
When a straight bar was clamped on you could see the "correct markings and the end would be 10mm or so off the block so height could be checked
They seemed like they were made out of cheese 😆
