Post by lcmarky on Aug 10, 2020 11:14:29 GMT 1
Post by earthman on Aug 10, 2020 11:52:18 GMT 1
My guess is like with the LC clocks, it's just a case of prising that black ring off first, trying to get a section of that 'lip' to stand proud basically.
I'd like to see the equipment used to assemble that, anyone even tried to make a press/die to aid in doing that??
Post by lcmarky on Aug 10, 2020 12:07:44 GMT 1
It's all plastics unlike LC clocks which have a metal bezel & are rolled over the edge with a press in manufacture I assume. This is probably US welded I'd guess and is the only join in the whole thing (apart from the face to bezel.
Post by lcmarky on Aug 10, 2020 12:09:46 GMT 1
I'm going to have to try to work a knife or similar into the bezel/case join. Either that or cut the body.
Still available new from Aprilia if all else fails...
Post by chrisg on Aug 10, 2020 12:18:49 GMT 1
I'm going to have to try to work a knife or similar into the bezel/case join. Either that or cut the body. Still available new from Aprilia if all else fails... If you have a drimmel type cutter that would work.
Post by lcmarky on Aug 10, 2020 12:47:17 GMT 1
I'm going to have to try to work a knife or similar into the bezel/case join. Either that or cut the body. Still available new from Aprilia if all else fails... If you have a drimmel type cutter that would work. I do, but then I'll remove loads of material,,
Post by chrisg on Aug 10, 2020 12:54:48 GMT 1
Could you not just take the lip of it and glue it back one you have done your surgery?
Post by lcmarky on Aug 10, 2020 12:58:23 GMT 1
I'm going to try and prise off the bezel..
Post by earthman on Aug 10, 2020 15:43:47 GMT 1
It's all plastics unlike LC clocks which have a metal bezel & are rolled over the edge with a press in manufacture I assume. This is probably US welded I'd guess and is the only join in the whole thing (apart from the face to bezel. Ah, that's a bugger, thought that it were metal.
Post by lcmarky on Aug 10, 2020 16:14:54 GMT 1
Trying to open it up just deforms and breaks the plastic.. New one it is then!
