Renthals
Aug 8, 2020 17:48:24 GMT 1
via mobile
Post by st66 on Aug 8, 2020 17:48:24 GMT 1
This may be a problem or may not be,, so planing on putting rental bars on my hybrid,, with some yokes from Andy when I eventually get around to sorting them my question is tho, power valve engine 31k,, will the cables reach in standard lengths,, clutch throttle ect useing standard 4l0 switch gear throttle,, or maybe 2008 r1 converted not decided as yet but and yes I know 2008 r1 is fly by wire throttle so anyhow for now let's say standard 4l0 switchgear ect,, do I have to take an inch or so off the end of the bars or,, anyone done this modd here renthal 7/8 or twinwall bars cheats antπ
Renthals
Aug 8, 2020 17:54:25 GMT 1
via mobile
Post by flames on Aug 8, 2020 17:54:25 GMT 1
Rental bars? Wouldn't you be better buying them? π Never fitted them myself but seeing as LC came with bars I wouldn't have thought it would be a problem... unless they are exceptionally wide / high?
Renthals
Aug 8, 2020 18:03:13 GMT 1
via mobile
Post by st66 on Aug 8, 2020 18:03:13 GMT 1
Well bought them already flames mate but not sorted my yokes from Andy as yet was just one of those thinking ahead questions mate to see if I had to factor in longer cables into the build list is all mate if that makes better sense lol,, there a motocross bar so think just a bit wider maybe than standard lc ,, but I'm a dab hand with the air saw lol
Post by st66 on Aug 8, 2020 18:04:59 GMT 1
Just read that again!!! Rental bars? Buying them? Soddin b*****d predictive feckn text agggggghhhhhhhh melt down
Renthals
Aug 8, 2020 18:06:41 GMT 1
via mobile
Post by midlifecrisisrd on Aug 8, 2020 18:06:41 GMT 1
Think I used a 51L or 1ar ypvs clutch cable and a 29l ypvs throttle cable
Renthals
Aug 8, 2020 18:11:02 GMT 1
via mobile
Post by st66 on Aug 8, 2020 18:11:02 GMT 1
Belta cheers Steve will lokk for those ππ
Renthals
Aug 8, 2020 18:20:58 GMT 1
via mobile
Post by midlifecrisisrd on Aug 8, 2020 18:20:58 GMT 1
That was without cutting the bars and running a billet manifold
The LC cables were too short
Post by st66 on Aug 8, 2020 18:44:05 GMT 1
Good man,, read my mind,, re billet manifolds so yvps cables it is, I live no far from the venhill factory so should be easy sorted cheers again Steve
Post by veg on Aug 8, 2020 19:56:33 GMT 1
Most of us fitting these bars to a 4L0 cut an inch of each side to decrease the width.
Post by dusty350 on Aug 8, 2020 21:05:02 GMT 1
Yea, I cut an inch off each end of a Renthal low rise bar too. They were like something out of "Queezy Rider" otherwise Imo, the bars look better if a bit more compact, but each to their own. Low rise Renthals - 758's, seem the best fit for looks and getting everything to work "length wise", not too far, if any, from a standard Lc2 set up I would think. Dusty
Renthals
Aug 8, 2020 21:29:20 GMT 1
via mobile
Post by st66 on Aug 8, 2020 21:29:20 GMT 1
Well thanks guys,, good advice from all so I will sort my yokes out from Andy and see if the air saw has its day,, which is likely as not wanting easy rider look π
Post by JonW on Aug 9, 2020 0:19:21 GMT 1
just hacksaw them slowly. Theres plenty of talk about renthal bars on here from not very months back.
