2taol
Post by 2taol on Aug 8, 2020 16:55:54 GMT 1
I wanted to start my engine build today and while unpacking bags to locate various parts I realise im missing a bearing clip #3. its the full clip not a half moon one.
Q1. is how many clips do I need?
I make it 4, 3 x Half moon and 1 full one.
Q2. where the half moon clips are located, do I need to double up, one top and one bottom?
Making the total 7
Post by dusty350 on Aug 8, 2020 18:08:19 GMT 1
Hi I,ve not got a fiche for a 250b, so I looked on the Fowlers website which shows the bottom end. As expected, the half clips are the same in later model Rd's as well as Lc's. So a half clip for the crank, a half clip for the output shaft on the sprocket side, and a small half clip behind the idler gear. A full clip goes on the large bearing behind the clutch basket. So 2 large and 1 small half clips and a larger clip for the clutch bearing. Dusty
2taol
Post by 2taol on Aug 8, 2020 21:32:13 GMT 1
Thanks for the confirmation dusty.
Dont tell anyone...I found the full clip still attached to the old bearing, feckin' looking through all the bits and bobs for it.
