Post by roblc350 on Aug 1, 2020 8:41:07 GMT 1
Hi All Iv got a 31k engine in a F2 frame with F2 loom only one of the plugs from the engine match up with the loom need help / advise on the other plugs / wires or were i can find the info i need iv looked but cant find
Cheers
Post by andy748 on Aug 1, 2020 17:30:49 GMT 1
Rob, check out the info on Norbo's site, all the stator compatibility is there and it's easily doable, you just need the wires swapping and new plugs attaching, also there will be no feed for the tacho as 31k is cable driven, but easy to recify and only if running F2/N2 clocks just do a search on this here forum. Andy.
Post by roblc350 on Aug 2, 2020 9:32:28 GMT 1
Thanks To Andy for his input & messsages I Was really hoping someone had come across this issue before..surely im not the only one with a F2 With a 31k engine in it What Engine was the F2 fitted with as standard so it was a plug & play set up without the changes my flywheel is marked 29L - 50..I Have 2 cdi"s at hand 1ua-50 52y-50..i already have the clocks / swithes Here"s Hoping Cheers
Post by midlifecrisisrd on Aug 2, 2020 11:10:18 GMT 1
The 1ua cdi is the correct one for an F2 so should plug straight into the loom
Personally I'd take 31k stator and flywheel off and sell them along with the 52y50 cdi and use the money to buy an f2 stator/flywheel to fit to the 31k engine
That's the easiest plug and play option as everything will match
Post by roblc350 on Aug 2, 2020 15:10:21 GMT 1
Thanks very much Steve I shall be definitely looking into that Guess il be posting a wanted ad for a F2 stator & flywheel
Thanks again
Post by jessy03 on Aug 2, 2020 18:20:07 GMT 1
Might have an F2 flywheel/stator if you want to swop, I’ll have to check. Jess
Post by roblc350 on Aug 2, 2020 18:22:33 GMT 1
please jess
Post by jessy03 on Aug 2, 2020 21:30:17 GMT 1
I’d probably sell the other parts and buy a Zeeltronic, I’ll check tomorrow to see what I have Jess
Post by roblc350 on Aug 2, 2020 21:42:00 GMT 1
Cheers Jess
Post by mak595 on Aug 3, 2020 14:25:48 GMT 1
If you get stuck, i've got a F2 flywheel...
Post by roblc350 on Aug 3, 2020 14:55:34 GMT 1
Cheers mate i maybe in touch
Post by andy748 on Sept 13, 2020 9:53:24 GMT 1
If you get stuck, i've got a F2 flywheel... Hello Mate, If Rob doesn't want your F2 flywheel i may be interested in it? Thanks, Andy.
Post by roblc350 on Sept 13, 2020 10:06:46 GMT 1
Im sorted on that front Andy.... Thanks to Jess so go for it
Rob
Post by mak595 on Sept 13, 2020 10:25:37 GMT 1
If you get stuck, i've got a F2 flywheel... Hello Mate, If Rob doesn't want your F2 flywheel i may be interested in it? Thanks, Andy. No worries, bung me postage and it's a swop for the side stand 👍
Post by andy748 on Sept 13, 2020 11:17:58 GMT 1
Thanks mate, I’ll bung a tenner in yer Paypal. Thanks Andy.
Post by andy748 on Sept 13, 2020 11:23:17 GMT 1
All done mate. Cheers, Andy.
Post by mak595 on Sept 13, 2020 12:42:54 GMT 1
All done mate. Cheers, Andy. cheers, i'll send you a pic just to make sure its ok for you....
