Post by baz69 on Jul 30, 2020 11:50:52 GMT 1
Morning all,curious to do a leak down test on my 4l0, just wondering what kits do you use or if you could point me in direction where to buy one,is their a 2 stroke specific one or is it general use,thanks.
Post by ERic350 on Jul 30, 2020 12:58:17 GMT 1
Post by stusco on Jul 30, 2020 14:06:23 GMT 1
That looks a good kit ill have one of those please ive broke a few plastic ones and always have leaks on the carb bungs
Post by JonW on Jul 30, 2020 14:26:25 GMT 1
I had a 3D printed kit from a guy on here and it just didnt last causing leaks in use as the plastic delaminated and cracked on all the parts so in the end I bought plumbing pipe ends and put in my own schrader valves and made flat plates for the exhausts from 10mm alloy and reused the rubber seals in the kit. It really wasnt that hard to do. Take an inlet rubber to the hardware store to find what plumbing end caps / pipe (with and end cap on it) fits and then make a plate. really not hard. Buy a nice low pressure (you only need 5psi to do the test) gauge and use a hand pump on the other valve if you put one in each inlet etc.
Post by ERic350 on Jul 30, 2020 14:39:14 GMT 1
And when there is leakage in the kit it's mostly on the exhaust side. Difficult to seal 100% when rubber is wearing down. For this I bought some rubber stops. Cut them in half so the matal plate can still be used while putting the rubber stop over the exhaust port. No more leaking problems over time  And also handy for painting a tank. www.rubbermagazijn.nl/rubberstop-grijs-d-36-44mm-h-40mm-set-5-stuks_grijs_21940.html
Post by steven on Jul 30, 2020 17:46:01 GMT 1
Post by alankelly on Jul 31, 2020 17:42:37 GMT 1
I had a 3D printed kit from a guy on here and it just didnt last causing leaks in use as the plastic delaminated and cracked on all the parts so in the end I bought plumbing pipe ends and put in my own schrader valves and made flat plates for the exhausts from 10mm alloy and reused the rubber seals in the kit. It really wasnt that hard to do. Take an inlet rubber to the hardware store to find what plumbing end caps / pipe (with and end cap on it) fits and then make a plate. really not hard. Buy a nice low pressure (you only need 5psi to do the test) gauge and use a hand pump on the other valve if you put one in each inlet etc. 3d printed kit Not guilty my lord 😁😁😁 Must have been somebody else Best wishes Al
Post by oldbritguy on Jul 31, 2020 18:21:45 GMT 1
Your stuff is too good Al
Post by JonW on Jul 31, 2020 23:46:53 GMT 1
I had a 3D printed kit from a guy on here and it just didnt last causing leaks in use as the plastic delaminated and cracked on all the parts so in the end I bought plumbing pipe ends and put in my own schrader valves and made flat plates for the exhausts from 10mm alloy and reused the rubber seals in the kit. It really wasnt that hard to do. Take an inlet rubber to the hardware store to find what plumbing end caps / pipe (with and end cap on it) fits and then make a plate. really not hard. Buy a nice low pressure (you only need 5psi to do the test) gauge and use a hand pump on the other valve if you put one in each inlet etc. 3d printed kit Not guilty my lord 😁😁😁 Must have been somebody else Best wishes Al Yes it was not from you Al. I forget the name of the guy it came from, nice guy but the kit fell apart over time sadly.
Post by jon on Aug 1, 2020 11:51:43 GMT 1
3d printed kit Not guilty my lord 😁😁😁 Must have been somebody else Best wishes Al Yes it was not from you Al. I forget the name of the guy it came from, nice guy but the kit fell apart over time sadly. Maccas? Jon
Post by JonW on Aug 1, 2020 13:13:16 GMT 1
I think so Jon.
