Post by bertiemollie on Oct 14, 2009 7:20:32 GMT 1
Hi Guys, Will be buying tyres for my Mk2 125 shortly . What make a tyre range should I be on the look out for? Std are: 80/100-16 45P Front 90/90-18 51P Rear I see Norbo sells: Michelin M45 or Pirelli Demons. Are these a good choice? Many Thanks Andrew
Post by rd50084matt on Oct 14, 2009 16:22:04 GMT 1
Hi Andrew
ive just put Pirellis on mine,in slightly wider sizes from the skinny standard ones as my bikes non std,michelin m45,s are ok but abit budget really ive got them on my fizzy!!..lol.Gotta admit tho bikes not on road yet so no chance to try em out....
i thought for an extra twenty quid id rather have good grip/more modern tyres/compounds?
end of day its personal taste i guess?
cheers
matt
Post by twostroker on Oct 14, 2009 20:59:48 GMT 1
my 175cc rd125lc had 90/90/16 front and 110//90/18 rear and handled reasonably well, i cant remenber the exact model of tyre but they were tubless pirellis with inner tubes fitted as the valve hole in the wheel is different size to that of a tubless valve
Post by bertiemollie on Oct 14, 2009 21:42:43 GMT 1
Thanks guys,
So are the Pirellis a more modern tyre / compound?
Post by rd50084matt on Oct 16, 2009 19:35:55 GMT 1
Andy Bolas has a mint mk2 in CMM mag this month has M45,s on it on a mk2 gaz??
Post by justinglos on Oct 17, 2009 23:12:22 GMT 1
i thought the standerd irc tyres was the best for me good all rounder the trouble with the michlein found a bit twitchy in the wet
Post by bertiemollie on Oct 18, 2009 0:09:20 GMT 1
i thought the standerd irc tyres was the best for me good all rounder the trouble with the michlein found a bit twitchy in the wet Hi Justin, Thanks for that. Do you know what tyres were fitted as std on the mk2?
Post by rd50084matt on Oct 18, 2009 21:24:29 GMT 1
Bertie think post above is the tyre?IRC in std sizes?
as for m45,s like i said have em on my fizz spcial and theyre twitchy!!!still betta than cheng shins tho..lol
Post by justinglos on Oct 25, 2009 15:44:43 GMT 1
hi bertie i used standerd front i think it 90/90 and the rear was the same as they used on the tzr they were called IRC marbellers i still have the front one on mine great tyres if you google them you will find deffo use them on mine again www.irc-tire.com/mce/ they are nr28 rear nr21 front
