kri101
Athena
Jul 18, 2020 12:34:07 GMT 1
via mobile
Post by kri101 on Jul 18, 2020 12:34:07 GMT 1
Hi any advice regarding the Athena big bore kit for the 250. I'm thinking carbs, ignition, oil pump yes or no, set up advice, Exhausts etc. So only a small list 😁
Athena
Jul 18, 2020 13:09:19 GMT 1
Post by Deleted on Jul 18, 2020 13:09:19 GMT 1
The bottom end for a 250 including cases are the same as a 350 so big bore bits will fit, 392, 421 cc and upwards are available
Lots of info on here on them, just use the search function
If you have an LC then Fahrenheit do a 374cc ? reline for 250 barrels
Everything is not cheap, however results are darn good
Post by arrow on Jul 18, 2020 19:42:46 GMT 1
You can run an oil pump, no problem. It needs to be a 350 pump thats been uprated, and a 350 wormshaft to go with it.
kri101
Athena
Jul 19, 2020 11:54:13 GMT 1
via mobile
Post by kri101 on Jul 19, 2020 11:54:13 GMT 1
Hi arrow, thanks I understand you do pump refurb, can you do a 250 to upgrade for the Athena or do I need a 350, do you have a link I can contact you on ?
Post by arrow on Jul 19, 2020 11:58:54 GMT 1
Hi arrow, thanks I understand you do pump refurb, can you do a 250 to upgrade for the Athena or do I need a 350, do you have a link I can contact you on ? I will send you a pm.
Post by arrow on Jul 19, 2020 12:07:58 GMT 1
Sent.
Athena
Jul 19, 2020 13:33:59 GMT 1
Post by JonW on Jul 19, 2020 13:33:59 GMT 1
Look on my website under 'upgrades' for the big bore primer. That may help.
