Post by shergar on Jul 9, 2020 22:56:36 GMT 1
hi the clutch leaver shakes / lifts up and down even with cable connected am i missing a bushing in the lever or the handle bar bracket or what ? ta
Post by roach3 on Jul 10, 2020 1:31:02 GMT 1
think there should be a collar in the clutch perch where the bolt goes through
Post by shergar on Jul 10, 2020 15:12:25 GMT 1
anyone have a picture of collar ?
Post by earthman on Jul 10, 2020 15:30:00 GMT 1
Maybe it's worth looking at diagram on Fowlers website for example, that may show the bush/sleeve??
Post by hoist1 on Jul 10, 2020 15:41:14 GMT 1
Think Fowler’s diagrams show a separate Bush but the levers have one integral. Not just wear then?
Post by 4l04ever on Jul 11, 2020 20:21:38 GMT 1
Take the lever off and put the bolt through it to see if there is play. If so, you will need to replace whatever is worn. The perch also wears where the lever fits becoming loose up and down, but you can squash it shut a little until it is a better fit.
There is no separate bush. There is a small o-ring, which is supposed to be in the groove in the lever.
