Post by foxyfeeling on Jun 28, 2020 20:28:43 GMT 1
Hi all I need some help and inspiration my rd250lc clutch seems to be slipping a bit when the engine warms up . So I would like to upgrade my plates,springs or even put a lock out clutch. What have other people used I would like to hear your opinion . Cheers Rob
Post by dusty350 on Jun 28, 2020 20:37:11 GMT 1
Hi I fit Ebc frictions and steels, and 3 of the stiffer springs that come in the kit. DRC043 is the part number, I think. Not all aftermarket clutch plates are the correct thickness, but these are. Don't think you'll need a lock up clutch Dusty
Post by JonW on Jun 29, 2020 1:07:17 GMT 1
Check the length of the springs, yam springs are made weakly and chances are springs is all you need on a standard bike and new OEMs are cheap.
Post by chrisg on Jun 29, 2020 10:28:54 GMT 1
What oil do have in your gearbox?
Post by Gitram on Jul 1, 2020 8:03:15 GMT 1
would you still have the rubber rings between the clutch plates? if so try taking them out first.. could be a cost effective solution
marti
Post by chrisg on Jul 1, 2020 12:58:11 GMT 1
Without the rubber rings the clutch may drag.
