Post by rd50084matt on Oct 1, 2009 13:33:57 GMT 1
HI
i know theres a post somewhere?that shows the location/fitting of loom correct route etc for a mk2,cant find it,anyone got a linky please,also anyone know who does the original type connectors to attach from cdi to loom(my orig plug has got a stray wire)and the two wires coming from the stator(no plug atm) to the loom..any help appreciated,its giving me a headache!!!!! lol
cheers
matt
Post by mellow on Oct 1, 2009 16:32:18 GMT 1
Post by rd50084matt on Oct 1, 2009 18:18:58 GMT 1
Thanks Mellow,wiring pics are great.
my loom is correct,with all original plugs but looknig at it just now the 2 pin from the loom(male) to the pick up wires(r/w & g/w)needs a matching 2 pin (feamle) socket,and my reg also has perfect 3 pin plug on loom end but the reg plug has a knackered wire,is it possible to get the correct type of plug as i only need one half of each?
Matt
Post by mellow on Oct 1, 2009 18:44:35 GMT 1
the towzer stuff is pretty spot on.if they are slightly different shape from original u could remove the connectors from original plug then just fit them into the towzer connector
Post by rd50084matt on Oct 1, 2009 20:44:53 GMT 1
Hi
ok ill give them ago just thought id clarify what the problems were in case id missed something obvious,thanks again mate
matt
Post by mellow on Oct 1, 2009 23:19:37 GMT 1
Post by rd50084matt on Oct 12, 2009 19:31:14 GMT 1
Hi
all sorted now,got charged battery on and loom/electrical bits loosely in place and everything works as it should even the warning lights!!...spark at plug too so looks like can get on with bodywork now...thanks again for all help & advice.
Matt
