Post by rattler on Jun 17, 2020 15:37:27 GMT 1
Hi - does anyone have experience or have a SV650 front end in a 4L0? interested in fit / issues / disks / wheels / calipers etc Thanks
Post by JonW on Jun 18, 2020 0:35:53 GMT 1
No, but I tried a SV650 shock once and its a horribly cheap thing. If they spent the same sort of budget on the front end then I'd avoid it.
Post by midlifecrisisrd on Jun 18, 2020 9:00:25 GMT 1
As Jon says it's probably a bit budget but most likely still better than standard
If going to all that hassle and rwu would you not be better with gsxr srad front end with risers
Post by Deleted on Jun 18, 2020 9:36:11 GMT 1
If you put an SV650 front end in an LC it will
1 - keep you busy for a bit 2 - cost you a bit of money 3 - make you realise the original stuff isn't that bad 4 - end up with a pile of useless SV650 bits to sell/donate
Or put another way don't bother
Post by rattler on Jun 18, 2020 21:22:00 GMT 1
If you put an SV650 front end in an LC it will 1 - keep you busy for a bit 2 - cost you a bit of money 3 - make you realise the original stuff isn't that bad 4 - end up with a pile of useless SV650 bits to sell/donate Or put another way don't bother thanks - I've scrapped the SV650 route now - just had access to a cheap(ish) front end of a SV650N - might see of the disks / calipers can be utilised though
