Finner
On a mission.
Post by Finner on Jun 17, 2020 12:47:58 GMT 1
Hi All, Just a query about the work done on the inlet port of these early 4L0 barrels. The inlet has been opened up. Is this good or bad ? Depending on advice from you folks, I may move them on. I have a 350R. I am sure the cylinder head is somewhere. My vernier will not give a digital display so just took a rough measurement. Thanks, Terry
Finner
On a mission.
Post by Finner on Jun 18, 2020 13:58:08 GMT 1
Quick update, I have just checked the other barrel (which I should have done in the first place !) Turns out this is not tuned and is actually the later type 4L0. So I have a pair of mismatched barrels ! I will try to source a cheap vernier and measure the bore. I am sure I can trade the good barrel for something. Regards, Terry
Post by midlifecrisisrd on Jun 18, 2020 19:54:10 GMT 1
Quick update, I have just checked the other barrel (which I should have done in the first place !) Turns out this is not tuned and is actually the later type 4L0. So I have a pair of mismatched barrels ! I will try to source a cheap vernier and measure the bore. I am sure I can trade the good barrel for something. Regards, Terry What side is the later barrel Know someone with 1 early and someone with 1 late May be able to sort everybodies mismatch lol Steve
Finner
On a mission.
Post by Finner on Jun 19, 2020 13:21:21 GMT 1
Post by midlifecrisisrd on Jun 19, 2020 13:34:57 GMT 1
Bugger
In typical style it's an early right I'm looking for to match up
Finner
On a mission.
Post by Finner on Jun 19, 2020 13:52:28 GMT 1
Yep, Typical !
Dare I ask Steve, do you know anyone with a good left 4LO later type ? Thanks, Terry
Post by midlifecrisisrd on Jun 19, 2020 15:02:13 GMT 1
I wish I did
The problem is a good mate has an early pair but the right is scrap hence why I am looking
I know where there is a later right so looking for an early right or a late left
Post by veg on Jun 19, 2020 15:31:38 GMT 1
Alternatively sell them?
To me 😁👍
Finner
On a mission.
Post by Finner on Jun 19, 2020 17:08:42 GMT 1
An early right followed by a late left. I must be on a boxing forum !
Veg, the delivery man has arrived so off you go !
Post by bare on Jun 23, 2020 2:03:22 GMT 1
It's Not possible to 'measure the Bore" with a caliper. One needs a bespoke bore gauge used by experienced hands. Otherwise a Ruler is as accurate
Post by tacky1 on Jun 23, 2020 2:59:52 GMT 1
Terry. Would you not try to get both barrels port matched. Not that difficult to do to be honest. It wouldn’t matter then if you used a later and newer barrel then as they are both the same inside. The barrel doesn’t look too bad. Bore them both out to take the same pistons.
Finner
On a mission.
Post by Finner on Jun 23, 2020 12:01:35 GMT 1
Good idea tacky1,
The problem I have is I have no bike to put them on ! I have a 350R. Good idea though. I also have another small problem with getting any machining work on barrels etc. There is no one that I know of in Ireland that does this work. There are no 2 strokes except for small scooters. The two last places that I knew of closed their doors many years ago. Cheers, Terry
Post by tacky1 on Jun 23, 2020 16:00:21 GMT 1
Terry, Ill PM you, I know a guy that has a place in Mullingar, We can check and see if he is still at it, I bet he is....
