gidsrz350
Two-stroke crazy fan
Post by gidsrz350 on Jun 15, 2020 18:43:52 GMT 1
Is there any difference between the Yamaha RZ350RR (full fairing) and RZ500 Instrument Clusters because the look the same?
Post by tacky1 on Jun 15, 2020 21:04:47 GMT 1
Not sure, but the 500 doesn’t have a mechanical rev counter and the 500 has a 16 inch wheel. So that might throw off the proper speed you are traveling at.
Post by JonW on Jun 17, 2020 1:31:20 GMT 1
not really. The speedo is different, but the rest is the same both have leccy tacho. The speedo will work on the other bikes, tho as tacky says im not 100% sure of the rolling radius of the wheel and the gearing etc.
Post by midlifecrisisrd on Jun 17, 2020 9:02:17 GMT 1
not really. The speedo is different, but the rest is the same both have leccy tacho. The speedo will work on the other bikes, tho as tacky says im not 100% sure of the rolling radius of the wheel and the gearing etc. I was looking at this for my kettle/TR project From what I found all Yamaha and Suzuki speedometers have a 2240:60 ratio Think that means 2240 rpm equates to the gauge reading 60 mph So in theory it is the drive that is slightly different on different diameter wheels Going from a 19 inch wheel down to a 17 I think I have a problem 🤔 Steve
Post by midlifecrisisrd on Jun 17, 2020 9:05:24 GMT 1
Oh and I assume the 500 will be the same as UK spec and have a higher speed on it
In UK 350 is 120mph scale. 500 is 150mph
Tzr250 is also 150 mph
Fz600 is 130mph
Rd350r (4ce) is 150 mph but there is no cut out for the self cancel reed switch. You can see the outline so it can be cut out easily
Post by JonW on Jun 17, 2020 13:45:57 GMT 1
not really. The speedo is different, but the rest is the same both have leccy tacho. The speedo will work on the other bikes, tho as tacky says im not 100% sure of the rolling radius of the wheel and the gearing etc. I was looking at this for my kettle/TR project From what I found all Yamaha and Suzuki speedometers have a 2240:60 ratio Think that means 2240 rpm equates to the gauge reading 60 mph So in theory it is the drive that is slightly different on different diameter wheelsGoing from a 19 inch wheel down to a 17 I think I have a problem 🤔 Steve Hmm, now youve got me thinking... you could probably swap these drives around to get one that works with what you are fitting. Ie the 500 is a 3m5-25190, which also fits the FJ1200 so is a factor of the ratio, the dimensions (tho they look very similar) and also the axle size. Here is a bunch of different ones, easy to check what bikes they are off and work out axle sizes etc www.google.com/search?q=yamaha+25190&tbm=isch&ved=2ahUKEwjSn_Co74jqAhX4nUsFHSYYBi0Q2-cCegQIABAA&oq=yamaha+25190&gs_lcp=CgNpbWcQA1C39gVY-4EGYLGDBmgAcAB4AIABjAGIAccHkgEDMC43mAEAoAEBqgELZ3dzLXdpei1pbWc&sclient=img&ei=HA_qXtKhPPi7rtoPprCY6AI&bih=941&biw=1893you could also remove the gears and fit them to other drives I reckon if you were keen, maybe the main gear is the only difference and the rest of the parts will work together (depends on the gears if they are paired etc), if so then you can just pop the gear out and try it on the drive you have. Roll the wheel the length of one revolution of the original wheel and count the speedo drive turns, you may well manage to get the numbers to work?!
