Post by noonster on Jun 4, 2020 20:15:41 GMT 1
whats the float height set at please.
bikes not starting,checked the height without gasket it was 17mm,adjusted to 23mm.
still not start,took carb bowl off could see any fuel
Post by noonster on Jun 4, 2020 20:26:21 GMT 1
Also tried the other carbs i had when i got the bike but are off cor d model still same,did have it runnng when i poured a little fuel into plug hole.
think i should refit the 2r9 carbs and set the float height correctly
Post by gazzatt2 on Jun 4, 2020 21:07:40 GMT 1
it is 23mm from the float bowl gasket is the fuel tap letting fuel through ?
Post by noonster on Jun 4, 2020 22:30:32 GMT 1
new tap
didnt see much fuel in bowl when i took it off.
this is after it at 23mm
clip is in mid postion on needle
Post by gazzatt2 on Jun 5, 2020 21:57:01 GMT 1
pull a fuel supply pipe of a carb direct into a container open tap see what flow you have is there plenty of fuel in tank ? or has it gone on reserve and you haven't realised
