Post by scott on May 28, 2020 21:56:49 GMT 1
Hi guys. Any of you chaps know if any different types of yamaha rear master cylinder repair kits fit the A/C one? Or a complete master cylinder that bolts straight on? Cheers guys.
Post by steeley on May 29, 2020 4:59:13 GMT 1
Hi , a mate of mine recently bought one for a 250e . He got it from yambits , sit down i think it was 47.99 . He reminded me i had fitted one 15 years ago when we restored the bike . I dryly said that means the tyres are 15yrs old then and need changing .
motty
Post by motty on May 29, 2020 7:19:11 GMT 1
You could contact Nick (NSRNICK on the Aircooled Forum, RDBitz if his website is working otherwise eBay) to see if he can sell a rebuild kit.
Post by scott on May 29, 2020 7:31:19 GMT 1
Hi , a mate of mine recently bought one for a 250e . He got it from yambits , sit down i think it was 47.99 . He reminded me i had fitted one 15 years ago when we restored the bike . I dryly said that means the tyres are 15yrs old then and need changing . Yes I know steely that's why I asked if anything else fitted, bit steep mate lol.
Post by scott on May 29, 2020 7:31:59 GMT 1
You could contact Nick (NSRNICK on the Aircooled Forum, RDBitz if his website is working otherwise eBay) to see if he can sell a rebuild kit. Ok cheers motty
Post by chrisg on May 31, 2020 20:42:12 GMT 1
I used the kit from yambits and the plunger did not fit. I had opened the kit, so was not eligible for a refund. In the end I used the seals and my original plunger and all worked well. Tip; Make sure the little return hole is clear from debris.
Post by scott on May 31, 2020 22:40:53 GMT 1
I used the kit from yambits and the plunger did not fit. I had opened the kit, so was not eligible for a refund. In the end I used the seals and my original plunger and all worked well. Tip; Make sure the little return hole is clear from debris. Ok thanks, I have seen 2 kits and one says its 14mm so I'll have to measure the one i have.
Post by chrisg on Jun 1, 2020 16:37:18 GMT 1
My kit was the correct kit, but badly made. I have red some people have removed some material from the OD of the plunger and it fitted ok. It was a bit annoying as the kit isn't cheap
motty
Post by motty on Jun 1, 2020 18:03:24 GMT 1
My kit was the correct kit, but badly made. I have red some people have removed some material from the OD of the plunger and it fitted ok. I do wonder if Nick Chambers does something similar on the masters cylinders he works on
dawn
Post by dawn on Jun 4, 2020 21:51:09 GMT 1
Post by scott on Jun 5, 2020 13:25:55 GMT 1
Ok thanks for that. That's the thing aswell crappy pattern parts that are not up to the job then you have to keep buying and buying. If your not fussed about it being standard it should be pretty simple to fab a bracket up to fit hole centres and do something with the plunger.
dawn
Post by dawn on Aug 2, 2020 19:43:45 GMT 1
I bought and fitted a seal repair kit to my master cylinder from Sax-moto. Not cheap at 43 Euros. Fitted easily and works perfectly.
Post by Gitram on Aug 3, 2020 9:30:38 GMT 1
