Post by dazzacfc on May 28, 2020 12:11:02 GMT 1
Hi all
I have just installed some AP Lockheed front brake calipers CP2696-38E0.
To get the best ratio / feel I am now looking for a different Front brake Master Cylinder., something with an 11 / 12 mm diameter bore, does anyone know of any master cylinders that have that size and would fit.
Cheers Dazza
Post by beardy on May 28, 2020 19:04:13 GMT 1
A while back I put 2 Lockheed callipers on my 350lc and they felt very wooden. After taking advice from this forum I put a 250lc master cylinder on and it’s far better now. I think the 250 one is 1/2”
Post by muttsnuts on May 28, 2020 20:03:55 GMT 1
A while back I put 2 Lockheed callipers on my 350lc and they felt very wooden. After taking advice from this forum I put a 250lc master cylinder on and it’s far better now. I think the 250 one is 1/2” correct, 250LC master cyl is 1/2" so 12.5mm which should be fine
Post by 4l04ever on May 29, 2020 0:41:42 GMT 1
YBR125 is 11mm. Takes LC mirror and uses same lever! Even takes the same front brake light switch!
