Post by tony2stroke on May 20, 2020 18:14:34 GMT 1
Normality has returned ๐ I thought Iโd heard of my first frivolous jock ๐คฃ๐คฃ๐คฃ Damn right, I paid ยฃ30 for the rebuild kits ๐ค Steve ๐ Were these Shyster Keyster carb kits bu any chance.
Post by midlifecrisisrd on May 20, 2020 18:29:32 GMT 1
Damn right, I paid ยฃ30 for the rebuild kits ๐ค Steve ๐ Were these Shyster Keyster carb kits bu any chance. The rebuild kits are the best bit of these carbs lol When I got the carbs they p1ssed fuel so I bought rebuild kits off eBay Yep they p1ssed fuel too. When float height was set at 21mm they overflowed. They needed 25mm to stop it Then I bought cruzin image kits from Japan. These worked I'm now sure the carbs have been altered irreversibly as I've clean ed them to within an inch of their lives and replaced all the jets with genuine It is the only explanation of how they were running pods safely with 1 size down from std main jet I'd never buy keyster due to their reputation Steve
Post by tony2stroke on May 20, 2020 18:41:07 GMT 1
Were these Shyster Keyster carb kits bu any chance. The rebuild kits are the best bit of these carbs lol When I got the carbs they p1ssed fuel so I bought rebuild kits off eBay Yep they p1ssed fuel too. When float height was set at 21mm they overflowed. They needed 25mm to stop it Then I bought cruzin image kits from Japan. These worked I'm now sure the carbs have been altered irreversibly as I've clean ed them to within an inch of their lives and replaced all the jets with genuine It is the only explanation of how they were running pods safely with 1 size down from std main jet I'd never buy keyster due to their reputation Steve I have had trouble with cheap needle valves and needle seats, but have been able to fix by a rub around the surface with a fine scotchbright pad on the needle and polish the end, and polishing the seat with autosol on a cotton bud after a rub with fine scotchbright pad, sometimes they have tinny burrs that make them stick. Worth a try I would say before you give up on these, if they stick open or closed or part way, then they will change jetting also.
Post by midlifecrisisrd on May 20, 2020 18:54:27 GMT 1
The rebuild kits are the best bit of these carbs lol When I got the carbs they p1ssed fuel so I bought rebuild kits off eBay Yep they p1ssed fuel too. When float height was set at 21mm they overflowed. They needed 25mm to stop it Then I bought cruzin image kits from Japan. These worked I'm now sure the carbs have been altered irreversibly as I've clean ed them to within an inch of their lives and replaced all the jets with genuine It is the only explanation of how they were running pods safely with 1 size down from std main jet I'd never buy keyster due to their reputation Steve I have had trouble with cheap needle valves and needle seats, but have been able to fix by a rub around the surface with a fine scotchbright pad on the needle and polish the end, and polishing the seat with autosol on a cotton bud after a rub with fine scotchbright pad, sometimes they have tinny burrs that make them stick. Worth a try I would say before you give up on these, if they stick open or closed or part way, then they will change jetting also. Good advice ๐ For now I'm done with these carbs The felting I don't have a problem with The issue is due to them being liked and the central push pull mechanism makes them the biggest ball ache to take on and off When they were first fitted the fuel level was so low it was getting fuel starvation when held open on the motorway It was still rich lol Steve
Post by bid on May 21, 2020 11:58:14 GMT 1
I'm having this same issue with my 350lc, no matter what i do its running so rich its just unbelievebly frustrating, top end is lame power, ok at 6 to 7.5k if i drop fuel levels 5mm below gasket, 31w carbs even dropped jets to 190 still same๐ค plugs are black and sooty looking but not wet and oily, hope you sort yours out ๐
Post by midlifecrisisrd on May 21, 2020 12:41:37 GMT 1
I'm having this same issue with my 350lc, no matter what i do its running so rich its just unbelievebly frustrating, top end is lame power, ok at 6 to 7.5k if i drop fuel levels 5mm below gasket, 31w carbs even dropped jets to 190 still same๐ค plugs are black and sooty looking but not wet and oily, hope you sort yours out ๐ Did you clean the emulsion tubes and behind the brass balls Behind the ball is the air correction circuit that feeds into the emulsion tube so affects the main jet If it's blocked then the extra suction caused by there being no air getting in will make a big difference Steve
Post by reedpete on May 21, 2020 12:58:59 GMT 1
I'm having this same issue with my 350lc, no matter what i do its running so rich its just unbelievebly frustrating, top end is lame power, ok at 6 to 7.5k if i drop fuel levels 5mm below gasket, 31w carbs even dropped jets to 190 still same๐ค plugs are black and sooty looking but not wet and oily, hope you sort yours out ๐ Agree with Steve could well be balls out time, but are you sure thatโs itโs a fuel issue and not high speed winding on the ignition ? No /poor sparks = sooty plugs..
Post by bid on May 21, 2020 13:56:06 GMT 1
Yeah ive had my balls out๐๐คฃ๐คฃ, i didnt think about the stator as i replaced it with a better condition one, but only have a cheap tester to test it with, numbers only marginly out, but the dry sooty looking plugs, you could be right,๐ญ thanks guys๐
Post by midlifecrisisrd on May 28, 2020 13:35:03 GMT 1
Got bored waiting for the 250 YPVS carbs to arrive so as I had just stripped and cleaned the 31k carbs for my leftovers build I thought it would be rude not to stick them on ๐
Had a pair of 210 jets so stuck them in and fitted the carbs along with an f1 cable
Would start on choke but revved it's nuts off, revs hung on and then wouldn't idle and boggy off throttle
Pulled them back off, changed from the 350 22.5 pilots up to 25's and fitted 250 air screws
Back on and started and idled straight away
Revs fine when blipping throttle
Took it out for a few miles and seems to be an improvement. A lot cleaner and willing to rev in the midrange and sounds totally different on the power
Now revs hard to 9 then a bit of a stutter. Will go to 9.5 if held
Reckon it's still rich up top but as I'm 3 sizes up on main and running 350 needles it's not surprising
Hopefully get the 250 carbs soon and get this sorted ๐
