Post by zig on May 15, 2020 8:58:34 GMT 1
Prestone coolant seems to tick all the boxes , can even be mixed safly with other brands , but wondering if anyone has used it ??
ZiG
Post by midlifecrisisrd on May 15, 2020 9:04:17 GMT 1
I've put it in my last 2 builds and have no probs
Post by zig on May 15, 2020 10:01:07 GMT 1
Thanks Steve ……….again ZiG
Post by zig on May 15, 2020 10:04:11 GMT 1
I've put it in my last 2 builds and have no probs Steve Just when you are there Steve , I want to remove the carb nozzle's from both body's , do they tap from the top out toward the bowl or upward to the cable top ?? Cheers in advance ZiG
Post by midlifecrisisrd on May 15, 2020 11:12:52 GMT 1
I've put it in my last 2 builds and have no probs Steve Just when you are there Steve , I want to remove the carb nozzle's from both body's , do they tap from the top out toward the bowl or upward to the cable top ?? Cheers in advance ZiG Unscrew the main jet, remove the washer then refit the jet finger tight Tap the jet and the emulsion tube should move up toward the carb top Steve
Post by zig on May 15, 2020 11:53:22 GMT 1
Just when you are there Steve , I want to remove the carb nozzle's from both body's , do they tap from the top out toward the bowl or upward to the cable top ?? Cheers in advance ZiG Unscrew the main jet, remove the washer then refit the jet finger tight Tap the jet and the emulsion tube should move up toward the carb top Steve I fitted LEDAR tubes some time ago but couldn't remember up or down....much appreciated Steve
Post by tacky1 on May 15, 2020 22:48:01 GMT 1
Use Prestone in all my bikes. Never a prob with cooling.
Post by midlifecrisisrd on May 16, 2020 11:40:00 GMT 1
Used the pink stuff before (can't remember make) and if there was a weak joint anywhere it would bloody find it
Post by nokturnal on May 16, 2020 12:35:50 GMT 1
I have heard that if you run the auto coolant to use the green and not the orange. Can’t remember why.
I use the green prestone in my street bikes
Post by tacky1 on May 16, 2020 19:45:48 GMT 1
I think the green has stuff in it to prevent scale and rust on iron parts, Orange is used in newer engines that dont have iron, LOL, Thats what I was told
Post by bare on Jun 16, 2020 3:39:00 GMT 1
I've used Honda Coolant (blue stuff) for 25 ! years now. In All my vehicles.. it's a 5 year lifetime swill. Zero cooling system issues of.. Any.. sort, for 2.5 decades and counting. It seemingly works :-) fit and forget.. V nice.
