busby
RD 350 4l0
Post by busby on May 8, 2020 17:07:03 GMT 1
Hi everyone, just a quick question. I took the clocks off my 4lo a while back to fix the broken tachometer. I am trying to fit it all back together but I can’t find the blue/red connector for the parking light. The wiring has not been messed about with and I assume it was there when I disconnected it. Anybody help with an idea where in the loom it appears in the headlight shell. Cheers
Post by oldbritguy on May 8, 2020 17:36:23 GMT 1
I think it comes from the connector block for the ignition switch.
busby
RD 350 4l0
Post by busby on May 8, 2020 18:12:46 GMT 1
The only blue/red I can see is in the 9way connector to the speedo. The Hanyes manual says they are colour coded for easy faulting😂. The wiring diagram shows it as a single connector so you would think it was obvious.
Post by oldelsieboy on May 8, 2020 18:23:06 GMT 1
The only blue/red I can see is in the 9way connector to the speedo. The Hanyes manual says they are colour coded for easy faulting😂. The wiring diagram shows it as a single connector so you would think it was obvious. It is obvious if you take oldbritguys advice OEB
busby
RD 350 4l0
Post by busby on May 8, 2020 18:34:35 GMT 1
Thanks for that guys. The reason I can’t see it is it’s broken off☹️. Something else to fix.
busby
RD 350 4l0
Post by busby on May 9, 2020 16:33:09 GMT 1
busby
RD 350 4l0
Post by busby on May 9, 2020 16:50:31 GMT 1
busby
RD 350 4l0
Post by busby on May 9, 2020 16:52:07 GMT 1
Thanks for the help guys
Post by badger69 on Sept 18, 2021 17:03:29 GMT 1
Hi can you please show me a picture of the small buld holder and where the 2 wires connect to please as i have an issue with mine, thank you very much
busby
RD 350 4l0
Post by busby on Sept 20, 2021 11:43:14 GMT 1
Hi badger, Do you mean the fitting in the headlight?
Mick
Post by badger69 on Sept 20, 2021 17:16:45 GMT 1
Hi badger, Do you mean the fitting in the headlight? Mick That would be great, I need all the help I can get, need to sort out my wiring issues, thanks mate.
Post by oldelsieboy on Sept 20, 2021 17:55:59 GMT 1
Hi can you please show me a picture of the small buld holder and where the 2 wires connect to please as i have an issue with mine, thank you very much The headlamp pilot light connects to a flying lead that comes from the ignition switch terminal and the multi bullet connection earth terminal. OEB
busby
RD 350 4l0
Post by busby on Sept 20, 2021 19:47:56 GMT 1
The blue red wire side of the bulb holder comes from the blue on the connector block. That is why I had to make a lead up to slide in by the wire as shown in the pictures.
Post by 4l04ever on Sept 20, 2021 21:12:31 GMT 1
You could eject the one connector and either replace it with two wires crimped in, or solder your replacement wire to the current connection.
