Post by markstrange350 on Apr 29, 2020 18:39:10 GMT 1
Hiya , has anybody posted about fitting a lockup clutch on their build ? I,m looking for any info , helpful tips etc before committing to buy one . Thanks 👍
Post by zig on Apr 30, 2020 9:16:54 GMT 1
Hiya , has anybody posted about fitting a lockup clutch on their build ? I,m looking for any info , helpful tips etc before committing to buy one . Thanks 👍 you need to consider if you want to run the 2 stroke pump or not ? reason being there are two different case's one that has it machined blank and the other still accepts the pump. fitting is simple and easy as long as you use new gaskets/seals and everything is clean it's a simple bolt on piece. Norbo has them in the shop here on line ZiG
Post by muttsnuts on Apr 30, 2020 10:14:01 GMT 1
which type of lock up clutch, there are several available and some can be used with a standard cover afrer a little modification to the cover
