Post by headcoats on Apr 28, 2020 9:27:29 GMT 1
I don't think we are using that many different types of needles for the PWK 28 carbs
So could we make a list of what we use and position of clip if possible
JJH N68 N99
Post by Tobyjugs on Apr 28, 2020 9:40:04 GMT 1
In Kees's tuned 4LO 350 with 28 mm PWK's i am using the N68, JJH left a big stutter. I was planning on buying two sets of Polini needles one set contains a complete range of needles for one carb. I have seen these being used on the dyno bank when setting bikes up. No issues. I haven't bothered as the bike runs well and i haven't had the time to even think about fine adjustments.
Post by midlifecrisisrd on Apr 28, 2020 11:49:51 GMT 1
N99 needle is for slide 4.0
JJH and N68 are 3.5
Post by Tobyjugs on Apr 28, 2020 13:19:41 GMT 1
What are you running with?
Post by midlifecrisisrd on Apr 28, 2020 15:18:55 GMT 1
I'm on JJH with mine with airbox
I used n68 with foam filters on the blue hybrid as that's what I was told when using airbox or pods
Post by jessy03 on May 1, 2020 22:29:18 GMT 1
I got some jjj’s Jess
Post by stusco on May 2, 2020 15:23:59 GMT 1
N68 needles clip in the middle position main 158 pilot 48,pod filters kennys pipes
Post by bare on Jun 16, 2020 3:44:59 GMT 1
JJH 130 mains 40 pilots Stock airbox ZERO missfires, stumble, hiccups or anything else. Zeel set to open PVs early and fully. Can't Imagine it running 'better'. And it burns a bit rich.. intentionally.
Post by marrcel on Nov 8, 2020 12:56:39 GMT 1
JJH 130 mains 40 pilots Stock airbox ZERO missfires, stumble, hiccups or anything else. Zeel set to open PVs early and fully. Can't Imagine it running 'better'. And it burns a bit rich.. intentionally. What is your needle position? Tia
Post by bare on Nov 16, 2020 17:36:00 GMT 1
Middle, although I've experimented some and found it made Small difference. That's the intrinsic advantage of Genuine Keihins...even Close Enough gives Better results than spot on with Mikuni. Buy old or fake PWKs and IMO none of this applies.
