Post by 4l04ever on Apr 14, 2020 22:17:34 GMT 1
I have always struggled to find an easy way, using a hammer with various bars, screwdrivers and drifts. Then I had a light bulb moment...
Post by 4l04ever on Apr 14, 2020 22:18:39 GMT 1
Pic
Post by 4l04ever on Apr 14, 2020 22:19:04 GMT 1
That was a lot easier! :-)
Post by Yogi on Apr 15, 2020 7:50:54 GMT 1
You should of asked 🥴 that’s how I’ve done it for years 👍
Also helps turning one edge up first before fitting if it’s originally flat
Post by LC_BOTT on Apr 15, 2020 7:55:48 GMT 1
Thats how I do all of mine, I also pre-bend the edge of the washers before fitting so they are easy to grab, and don't look like Frankenstein has smashed them to bits with a hammer and chisel. oops beaten too it
Post by JonW on Apr 15, 2020 7:58:11 GMT 1
I'd never thought of that either! funny how some of us have and some havent.
Post by muttsnuts on Apr 15, 2020 9:41:27 GMT 1
yep, use adjustable pipe grips like Rob, always done it that way
Post by Deleted on Apr 15, 2020 11:42:56 GMT 1
I use mole grips. Adjust them to the size of the nut, back it off a bit. Lift the tab with a wood chisel/hammer then flatten it against the nut with the grips. PoP :-)
It's a proper Eureka moment
Post by 4l04ever on Apr 15, 2020 15:46:26 GMT 1
Hopefully this thread will help others wo did not think of doing it this way. It is always good to find an easier way to do something.
Post by chrisg on Apr 16, 2020 11:59:02 GMT 1
I have some disc locking tabs to bend, so will try this method. Always managed to damaged my new painted disc in the past and have to touch up.
