Post by Stef on Mar 29, 2020 19:56:15 GMT 1
Hi All, I'm looking at doing a hybrid to an LC. Can someone give me the approx dimension from the swingarm spindle to the wheel spindle. I've got a couple of swingarm choices a FZ600 and a FZR400. I don't want the long swingarm look like you get with the rgv arms. I'm probably looking at spreading the frame.
Thanks.
Stef.
Post by dusty350 on Mar 30, 2020 9:13:03 GMT 1
Hi Centre of swingarm spindle to centre of chain adjustment slot is approx 18 and a quarter inches on an Lc swingarm.
Dusty😉
Post by Stef on Mar 30, 2020 9:14:42 GMT 1
Cheers Dusty.
Post by oldelsieboy on Mar 30, 2020 11:35:29 GMT 1
Hi All, I'm looking at doing a hybrid to an LC. Can someone give me the approx dimension from the swingarm spindle to the wheel spindle. I've got a couple of swingarm choices a FZ600 and a FZR400. I don't want the long swingarm look like you get with the rgv arms. I'm probably looking at spreading the frame. Thanks. Stef. If it's an FZR400 3EN swingarm, this is how it will look fitted. OEB
Post by Stef on Mar 30, 2020 11:49:32 GMT 1
Wow. If it comes out looking anything like that I'll be happy. That's the same swingarm as I have. Did you spread the frame or machine the arm?
Post by oldelsieboy on Mar 30, 2020 12:29:58 GMT 1
Wow. If it comes out looking anything like that I'll be happy. That's the same swingarm as I have. Did you spread the frame or machine the arm? The arm was machined to fit frame (not by me) OEB
Post by Stef on Mar 30, 2020 12:34:23 GMT 1
Wow. If it comes out looking anything like that I'll be happy. That's the same swingarm as I have. Did you spread the frame or machine the arm? The arm was machined to fit frame (not by me) OEB Hmmm. That was going to be my initial plan, but after reading up, it sounded like it was going to have to spread it. What size rear tyre are you running in there, 150? Any chain clearance issues? Stef.
Post by oldelsieboy on Mar 30, 2020 12:43:36 GMT 1
The arm was machined to fit frame (not by me) OEB Hmmm. That was going to be my initial plan, but after reading up, it sounded like it was going to have to spread it. What size rear tyre are you running in there, 150? Any chain clearance issues? Stef. Rear wheel is 3.50 x 17", tyre is 140/70, offset gearbox sprocket (8-9mm I think), no clearance issues. OEB
