Post by shergar on Mar 29, 2020 12:13:04 GMT 1
hi whats the standard and max barrel bore size lads as i just took mine off and did a measure and there 63 , cheers
Post by midlifecrisisrd on Mar 29, 2020 12:36:05 GMT 1
64 to 66mm so best check whatever you are using to check them 😀
Post by markhoopy on Mar 29, 2020 14:38:26 GMT 1
64 to 66mm so best check whatever you are using to check them 😀 Steve Most likely just got damp in storage and shrunk a little. Should be fine once they dry out
Post by shergar on Mar 29, 2020 14:54:39 GMT 1
must have been the new paint that made them shrink lol .
Post by 4l04ever on Mar 29, 2020 15:56:53 GMT 1
Could be a thick layer of rust???
Post by nokturnal on Mar 29, 2020 17:34:38 GMT 1
I have some stock bore barrels that measure 63.8 at the top...
Post by shergar on Mar 29, 2020 19:40:22 GMT 1
just remeasured after nokturnal reply and the exact size is 63.69 and 63.78 at the top
Post by 4l04ever on Mar 31, 2020 1:58:04 GMT 1
Standard bore is 64.00mm Should not be smaller!
Your measuring equipment may be at fault?
Post by nokturnal on Mar 31, 2020 2:31:37 GMT 1
its not the first time I have measured std bore smaller than 64... maybe they shrink in the cold...
i am not using a bore gauge, just verniers on the top of the jug
Post by bare on Mar 31, 2020 6:05:08 GMT 1
Without a Genuine Bore Gauge.. one might as well use a yardstick... it will be as accurate.
