Post by headcoats on Mar 20, 2020 12:59:49 GMT 1
It seems when the fuel taps start binding and become almost impossible to turn, is it down to this little cone shaped plastic piece ?
The white one was the one that is the newest Had to take mine out and is scored to f##k This is a genuine tap too
So is the solution to have this piece made from something that is ethanol proof ?
Or can Yamaha or Tourmax who make the good replacements make the part available separately for us to buy ?
Post by doohanno1 on Mar 20, 2020 16:56:17 GMT 1
Damn, i thought this maybe a link to some cheap blue tablets..but enough about my problems...
About a year ago i replaced a tourmax tap with another one because the lever was getting stiff..now the later one is starting to go the same way... I have another tank with a tourmax tap that has been on for a number or years and it is grand.. So i wondering is there a fine " sediment" in the former tank that is grinding away at that plastic piece..?
I wonder if the chap that makes the ypvs swing arm chain protector could make these up.?
Stiffy !
Mar 20, 2020 17:06:26 GMT 1
via mobile
Post by midlifecrisisrd on Mar 20, 2020 17:06:26 GMT 1
If you have an old tank with fuel in and the tap is ok that would suggest there is no ethanol in it
Post by doohanno1 on Mar 20, 2020 17:18:36 GMT 1
If you have an old tank with fuel in and the tap is ok that would suggest there is no ethanol in it Steve Sorry , the way i worded that was a little misleading.." other" tank is on a bike that is in use and gets the same fuel as the " stiff" one..
Post by steve h on Mar 20, 2020 17:50:02 GMT 1
Turn some out on a lathe?
