Post by marrcel on Feb 12, 2020 17:16:03 GMT 1
Can anybody measure a headstud for me? 50 leaves not much room to thighten the nut🤔 Old oem 45mm? And new 50mm yambits.
Post by ianboom on Feb 12, 2020 19:10:50 GMT 1
Which stud us it? I thought there were 3 different lengths on a ypvs??
Post by Tobyjugs on Feb 12, 2020 19:31:03 GMT 1
I would use the oem studs. Just for the feeling it is rated tor the correct torque.
There's a high chance that the YAMBITS stud is made from an inferior tensile strength steel ( pisbak staal)
Post by marrcel on Feb 12, 2020 21:03:11 GMT 1
Which stud us it? I thought there were 3 different lengths on a ypvs?? The head has 10 studs. Which are the same.
Post by ianboom on Feb 12, 2020 22:22:15 GMT 1
Sorry, was thinking of the barrel studs!
Post by marrcel on Feb 12, 2020 23:07:17 GMT 1
I think the 50mm just about fits. Still curious about oem size. 🤔
Post by marrcel on Feb 13, 2020 8:24:15 GMT 1
I will refrase my question. The old 45mm studs which came out, i dont know if these are original. What is the original length of the head studs.
Post by gavink on Feb 13, 2020 8:46:56 GMT 1
Post by muttsnuts on Feb 13, 2020 10:21:17 GMT 1
65mm are originals, got some new ones here
Post by tsa on Feb 13, 2020 10:48:24 GMT 1
65mm is the pipe studs on that site. part # 9011608365
24mm is the head studs on that site. part # 9011608424
Post by marrcel on Feb 13, 2020 15:51:43 GMT 1
Stud lenghts are sometimes not the same size measured with a plier? 65mm will never fit. Here a pic with 50mm studs. Which leaves 2.3mm and 1.5mm for the washer to thighten the nut.
Post by tsa on Feb 13, 2020 17:30:52 GMT 1
no the head nuts have long threaded extensions on that fit inside the head they arent like normal nuts.
Post by marrcel on Feb 13, 2020 18:08:44 GMT 1
Yes i know the nuts are longer. I had to clean a lot of copaslip out of them. Otherwise I couldn’t thighten the head.
Post by Tobyjugs on Feb 13, 2020 19:01:30 GMT 1
Looks like your good to go.
