Post by boomflamingo on Jan 24, 2020 13:03:10 GMT 1
Hi
Undecided whether to save these exhausts and sell then, or cut the ends off to use the flanges on a set of JL exhausts.
Don't want to waste the exhausts if they are useful, but if they have no value then may as well butcher them.
Advice please
Post by JonW on Jan 24, 2020 13:07:23 GMT 1
I have saved waaaay worse.
Post by abar121 on Jan 24, 2020 13:37:28 GMT 1
Save them.
Post by Dixie Dean on Jan 24, 2020 14:35:12 GMT 1
Looks too good to chop
Post by Deleted on Jan 24, 2020 15:46:43 GMT 1
Apart from the fact you've got two different types of exhausts, unless there are massive holes on the other side they look pretty good
Have a look at what JonW did to his in his rebuild thread, yours is a lot better starting point than his
Post by boomflamingo on Jan 24, 2020 15:57:06 GMT 1
Hi all
Thanks for advise
They are actually really solid, but two different exhausts, I am guessing one is not genuine.
I have decided to sell them on ebay, and just by some flanges from Tyga to make up.
Post by 4l04ever on Jan 24, 2020 15:58:06 GMT 1
They would fetch reasonable money. Probably worth £50+ each depending on the other sides, maybe more...
Post by oldelsieboy on Jan 24, 2020 18:14:33 GMT 1
Neither are much good, one from a YPVS & the other an original thin flange LC pipe. OEB
Post by muttsnuts on Jan 24, 2020 18:39:07 GMT 1
Neither are much good, one from a YPVS & the other an original thin flange LC pipe. OEB as OEB says, plus they are both LHS, so not a pair in any sense, they might be worth something to somebody who is looking for a LHS YPVS or early LC pipe, otherwise they aren't much use as is TBH
Post by oldelsieboy on Jan 24, 2020 20:36:36 GMT 1
Post by boomflamingo on Jan 24, 2020 21:41:27 GMT 1
Oh, so the one in the Ebay ad is for a YPVS?
Post by oldelsieboy on Jan 24, 2020 21:50:33 GMT 1
Oh, so the one in the Ebay ad is for a YPVS? Check the stamped number on the top face to the rear of the hanger bracket, should start 31k And as the pipe has the cutout/indentations to the inner edge at the rear it is for the later N/F models. OEB
