Post by midlifecrisisrd on Nov 30, 2019 18:23:41 GMT 1
UK 4L0 hpi clear 3 previous owners with v5 Can you guess why I'm cutting it up tomorrow? Steve 🤣🤣🤣
Post by steve h on Nov 30, 2019 18:27:47 GMT 1
Bent
Post by Yogi on Nov 30, 2019 18:34:24 GMT 1
Was Elton John the previous keeper
Post by midlifecrisisrd on Nov 30, 2019 18:40:40 GMT 1
There is a dog theme
Top pic is like the cute tilted head look
The second is hunched like a sh1tting dog 🤣🤣🤣
Post by jackjabba on Nov 30, 2019 18:42:58 GMT 1
Steve,I will take the swing arm plates if you still have them.
Jack
Post by ianboom on Nov 30, 2019 18:43:50 GMT 1
Steering rake looks a rad steep. Dibs on the ignition lock tab on the headstock if you're cutting it up
Post by Yogi on Nov 30, 2019 18:45:21 GMT 1
Can’t it be jigged?
Post by midlifecrisisrd on Nov 30, 2019 18:47:33 GMT 1
Steering rake looks a rad steep. Dibs on the ignition lock tab on the headstock if you're cutting it up Afraid the headstock is what's getting cut off first as someone has dibs on it 🙁 Steve
Post by midlifecrisisrd on Nov 30, 2019 18:49:06 GMT 1
Steve,I will take the swing arm plates if you still have them. Jack Are you talking about where the swing arm pivot bolts to? It's not mine, I'm cutting it for a mate I'll ask him what he wants Steve
Post by doohanno1 on Nov 30, 2019 18:51:02 GMT 1
Yeah, is that not worth saving.?
Post by midlifecrisisrd on Nov 30, 2019 18:52:03 GMT 1
It's beyond it I'm afraid Top rails should be straight and there are kinks on the brace rails Engine cradle also bulging out on one side Also as the centre stand, side stand and tie bar mounts already had been cut off for the replacement frame there's not much value in it Steve
Post by jackjabba on Nov 30, 2019 18:53:51 GMT 1
Steve,I will take the swing arm plates if you still have them. Jack Are you talking about where the swing arm pivot bolts to? It's not mine, I'm cutting it for a mate I'll ask him what he wants Steve Yes that’s correct.
Post by midlifecrisisrd on Nov 30, 2019 18:54:00 GMT 1
Yeah, is that not worth saving.? It's been to be checked and the killer is the headstock isn't just bent inward but has been pulled downward Whole frame is bent and buckled It has even pulled the rear tank mount out of place Steve
Post by doohanno1 on Nov 30, 2019 19:07:31 GMT 1
Yeah, is that not worth saving.? It's been to be checked and the killer is the headstock isn't just bent inward but has been pulled downward Whole frame is bent and buckled It has even pulled the rear tank mount out of place Steve I always wonder what kind of " incident " could cause this amount of damage..
Post by Gunny on Nov 30, 2019 20:11:23 GMT 1
Probably came from that guy in Nuneaton LLF
Post by midlifecrisisrd on Nov 30, 2019 20:13:10 GMT 1
Probably came from that guy in Nuneaton LLF Same standard but no rust 🤣 Steve
Post by midlifecrisisrd on Nov 30, 2019 20:14:39 GMT 1
Are you talking about where the swing arm pivot bolts to? It's not mine, I'm cutting it for a mate I'll ask him what he wants Steve Yes that’s correct. Sorry but he's wanting to keep the rest for spares in case he needs anything in the future Steve
