Post by dusty350 on Apr 18, 2021 21:29:03 GMT 1
That's a great result Chris Hopefully get that flat spot ironed out. I wonder why it didn't show up on the dyno ? And your missus obviously knows about Rd's. Left hand covering the clutch lever Dusty
Post by sidney81 on Apr 18, 2021 22:01:05 GMT 1
That's a great result Chris Hopefully get that flat spot ironed out. I wonder why it didn't show up on the dyno ? And your missus obviously knows about Rd's. Left hand covering the clutch lever Dusty it's strange it didn't at all it pulled from low down right through to top not a single stutter ,get it on the road and it's a different story !! Bit of a bugger but I'll keep fiddling π
Post by sidney81 on Apr 18, 2021 22:02:13 GMT 1
That's a good power output indeed! Alex ps is she modelling the new Alpine Stars slippers? ππshe said you can't put that on there I'm in my slippers !!!π
Post by Tobyjugs on Apr 18, 2021 22:49:41 GMT 1
Hi Sidney, good to see a bit of colour in the pipes. are you going to oil them or paint them? Did you run with the balance pipe on the dyno session? What reeds do you have fitted? How about a 10mm reed spacer fitted before the reeds it might knock a few hp off the top but it could give you better mid range to help cure the flat spot. I have found the best way to help with flats spots on a more peppy engine is to make sure the hole from the carb to the reed is one size with no huge areas between the different parts. Those LC intake rubbers have built in stuffer's which is a good thing and will match the LC reeds. Below is a reed with a stuffer. One nice round hole (no altering diameters) from your carb to your stuffer.
Post by 4l04ever on Apr 19, 2021 8:06:17 GMT 1
Reed spacers, boost bottles, YPVS inlet rubbers are a few more things to have a mess with. I think I have an LC boost bottle somewhere...
Post by sidney81 on Apr 19, 2021 8:43:16 GMT 1
Hi Sidney, good to see a bit of colour in the pipes. are you going to oil them or paint them? Did you run with the balance pipe on the dyno session? What reeds do you have fitted? How about a 10mm reed spacer fitted before the reeds it might knock a few hp off the top but it could give you better mid range to help cure the flat spot. I have found the best way to help with flats spots on a more peppy engine is to make sure the hole from the carb to the reed is one size with no huge areas between the different parts. Those LC intake rubbers have built in stuffer's which is a good thing and will match the LC reeds. Below is a reed with a stuffer. One nice round hole (no altering diameters) from your carb to your stuffer. hi bud that's interesting! I have yz 85 reeds that have been modded to fit ,the spacer is a option to try for sure ! I will try moving the filters back first see where that goes ! Thank you
Post by sidney81 on Apr 20, 2021 21:22:19 GMT 1
Hi ,I made some temporary tubes to move the filters back about 70 mm , tried it this evening and it's far worse the midrange stutter is now lower down !! ( Bugger) might get some reed block spacer's and try them ,I've got jjh needles in I've seen there are others available?
Post by Tobyjugs on Apr 21, 2021 6:15:30 GMT 1
Hi ,I made some temporary tubes to move the filters back about 70 mm , tried it this evening and it's far worse the midrange stutter is now lower down !! ( Bugger) might get some reed block spacer's and try them ,I've got jjh needles in I've seen there are others available? I love to see a bit of innovative testing. On a serious note I had JJH needles fitted to my carbs with pods and it had a bad flat spot as well. The engine was a 4L0. I ended almost curing it with changing the needles to 68A needles.
Post by sidney81 on Apr 21, 2021 6:25:00 GMT 1
Hi ,I made some temporary tubes to move the filters back about 70 mm , tried it this evening and it's far worse the midrange stutter is now lower down !! ( Bugger) might get some reed block spacer's and try them ,I've got jjh needles in I've seen there are others available? I love to see a bit of innovative testing. On a serious note I had JJH needles fitted to my carbs with pods and it had a bad flat spot as well. The engine was a 4L0. I ended almost curing it with changing the needles to 68A needles. hi ,I've ordered some reed spacer's to try to , as for the needles do you know where I can purchase some from ? Allen's?
Post by Tobyjugs on Apr 21, 2021 6:48:58 GMT 1
Yes Allen's but I'm having difficulty remembering the correct spec of the needle. N68A or 68A. Someone will read this and put me right hopefully. You will also find the spec in lots of other threads.
Post by sidney81 on Apr 21, 2021 7:02:11 GMT 1
Yes Allen's but I'm having difficulty remembering the correct spec of the needle. N68A or 68A. Someone will read this and put me right hopefully. You will also find the spec in lots of other threads. thank you π
Post by wallcraft on Apr 21, 2021 13:28:40 GMT 1
Yes Allen's but I'm having difficulty remembering the correct spec of the needle. N68A or 68A. Someone will read this and put me right hopefully. You will also find the spec in lots of other threads. They are N68X and N68A, I found that there wasn't much difference between the two when I was dialling mine in. Allens don't stock the N68X but they do do the very close N68A. Their stock number is N427-68-AOO. Think they were around Β£20 delivered, that was around 5years ago though. Mark.
Post by sidney81 on Apr 21, 2021 13:48:44 GMT 1
Yes Allen's but I'm having difficulty remembering the correct spec of the needle. N68A or 68A. Someone will read this and put me right hopefully. You will also find the spec in lots of other threads. They are N68X and N68A, I found that there wasn't much difference between the two when I was dialling mine in. Allens don't stock the N68X but they do do the very close N68A. Their stock number is N427-68-AOO. Think they were around Β£20 delivered, that was around 5years ago though. Mark. hi mark thank you thats brilliant I spoke with them today he didn't know what I was on about ,n68 etc I'll try that number thanks π
Post by wallcraft on Apr 21, 2021 13:51:19 GMT 1
Just remembered the other needle I discovered which again was a good match to the N68X was N427-46-HLH again from Allens. You should get it some were near with the 3 needle choices using foam filters. The JJH needle is good if using the air box . Be prepared for your brain to be frazed if it's not already with the different combos π¬
Mark.
Post by sidney81 on Apr 21, 2021 14:28:28 GMT 1
Just remembered the other needle I discovered which again was a good match to the N68X was N427-46-HLH again from Allens. You should get it some were near with the 3 needle choices using foam filters. The JJH needle is good if using the air box . Be prepared for your brain to be frazed if it's not already with the different combos π¬ Mark. it already is ha ha it's doing my head in ,and I've not got much experience with jetting etc ,all I know it's not happy in the midrange it's horrible ,thank you
chrisk
Post by chrisk on Apr 22, 2021 22:57:51 GMT 1
Hi,
I'm not sure of all your mods. Is it tuned at all, apart from pipes and carbs
One thing I did with a rd250 is change the reeds to the same as a 400, ie a stiffer reed on each block. Works well.
Post by sidney81 on Apr 23, 2021 7:02:39 GMT 1
Hi, I'm not sure of all your mods. Is it tuned at all, apart from pipes and carbs One thing I did with a rd250 is change the reeds to the same as a 400, ie a stiffer reed on each block. Works well. hi thanks for the comment, yes it's ported ,head skimmed ,domes re shaped squish set to 1 mm ,it's got yz 85 reeds in so it should be nice and stiff .Chris
Post by sidney81 on Apr 24, 2021 16:41:55 GMT 1
Hi everyone With some advice form a few guys on here I've got some different needles ,n68a and what a difference they make ! It's running well still needs some fine tuning but it's good ,I've fitted some reed block spacer's to to try and help but I've not tryed that yet ! .I also felt the gearing wasn't quite right I've got 17 front with a 37 rear Ive now gone to a 39 on the rear that should suit it better ! Going far a blast later see how it goes !! π
Post by Tobyjugs on Apr 24, 2021 19:23:38 GMT 1
Are the gearbox ratios similar to a 4LO? IF they are you should try a 41 tooth sprocket.
Post by midlifecrisisrd on Apr 24, 2021 19:41:49 GMT 1
Brilliant news the needles helped π
Post by wallcraft on Apr 24, 2021 21:45:26 GMT 1
Glad your nearly there, allens will have a rush on now.
Mark.
Post by sidney81 on Apr 25, 2021 8:26:52 GMT 1
Well the rear sprocket made a great difference ! And was lucky as the Chain was long enough to fit still Result!
Read block spacer's fitted to took it out and it's running good ,it sounds brilliant to ( very loud) I think the carbs are noisier than the pipes π,once I have the tank fitted I can go for a good ride and have a fiddle with the air screws etc but for now I'm leaving it how it is. Would you believe I've done 70 miles just going round the village testing with a lawnmower fuel tank strapped to the frame! 70 miles ha ha .
Post by steeley on Apr 25, 2021 9:51:14 GMT 1
Nice . I am looking forward to seeing this finished and watching the videos on you tube Chris . 70 miles, this will be nearly run in by the time its finished .
Post by sidney81 on Apr 25, 2021 10:01:58 GMT 1
Nice . I am looking forward to seeing this finished and watching the videos on you tube Chris . 70 miles, this will be nearly run in by the time its finished . it's crazy I'd never think I'd done that! I think my neighbor's will be happy when it's finished ππ
Post by sidney81 on Apr 25, 2021 10:14:28 GMT 1
I couldn't resist a sneeky pic! I'm so pleased with the tank .I met the sticker guy yesterday at the painters because my Paint Man doesn't get involved with them ! ( Don't blame him ) and wow it looks awesome!! He's lacquering it all next week I'm collecting it on Friday! Exciting π
Post by dusty350 on Apr 25, 2021 14:08:38 GMT 1
Looks awesome Chris I do love the Kenny colours on the aircooled bikes. Nearly opted for a shade of yellow myself, but went with the white/red as a nod to my original 400e, but it was a close decision. Nearly there now mate Look forward to seeing it with the bodywork fitted . Dusty
Post by sidney81 on Apr 25, 2021 14:11:30 GMT 1
Looks awesome Chris I do love the Kenny colours on the aircooled bikes. Nearly opted for a shade of yellow myself, but went with the white/red as a nod to my original 400e, but it was a close decision. Nearly there now mate Look forward to seeing it with the bodywork fitted . Dusty thanks dusty πit was a tough decision for me to make ha ha my Tzr is White n red so the Kenny got it π
Post by steeley on Apr 25, 2021 21:59:11 GMT 1
Hmmm , nice . Yes i know what it is like setting decals up . Sid looks to camera Yak yak yak .
Post by sidney81 on Apr 27, 2021 19:59:39 GMT 1
Hi everyone ,been rebuilding my petrol taps I stripped them and pulled one brass spigot out and welded the hole up because I'm running two taps so I only need one outlet each side ! Had them vapour blasted ,fitted new o rings ready for my tank on Friday π
Post by sidney81 on May 1, 2021 12:39:33 GMT 1
