Post by 3tj6 on Dec 5, 2020 20:31:41 GMT 1
Fantastic welding, i may have a tzr 250 front disc in the garage, was for a project in 88 but never used, will have a look tomorrow if you need one
Post by sidney81 on Dec 5, 2020 20:44:35 GMT 1
I'm going to use the high flow, single outlet Tz style taps that Norbo sells in his shop - they will be more than enough, bearing in mind they are feeding only 1 carb each Dusty Ok I didn't realize there single outlet !! Might be a game changer then ! That would be perfect π
Post by gazzatt2 on Dec 5, 2020 21:02:01 GMT 1
I use that tap and a t piece on 34mm round slide mikuni's have no problem with fuel starvation
Post by sidney81 on Dec 5, 2020 21:35:24 GMT 1
I use that tap and a t piece on 34mm round slide mikuni's have no problem with fuel starvation hi bud cool I'm going to use two taps one each side so they sound perfect ππ
Post by andy748 on Dec 6, 2020 10:11:37 GMT 1
RGV250 taps fit as well 8mm single outlet, plenty of flow. Andy.
Post by sidney81 on Dec 6, 2020 20:25:23 GMT 1
RGV250 taps fit as well 8mm single outlet, plenty of flow. Andy. hi bud , didn't know that cool I'll look into it thanks π
Post by sidney81 on Dec 8, 2020 21:29:10 GMT 1
Post by dusty350 on Dec 8, 2020 22:26:59 GMT 1
That's coming on a treat Chris Dusty
Post by sidney81 on Dec 8, 2020 23:57:46 GMT 1
That's coming on a treat Chris Dusty Thanks dusty π yep making progress with it π
2taol
Post by 2taol on Dec 11, 2020 22:39:16 GMT 1
....nice to see new bearings in place!
coming along nicely, you probably finish yours before mine !
Post by sidney81 on Dec 12, 2020 8:34:36 GMT 1
....nice to see new bearings in place! coming along nicely, you probably finish yours before mine ! Thanks bud ,tbh the old gearbox bearings felt fine they were smooth and tight so I nearly left them ! But I thought it would all be new if I replaced them . Oh I don't know about that π I still have lots to do ! I would love to have it finished for the summer !! π
Post by steeley on Dec 12, 2020 10:49:56 GMT 1
Nice .
Post by sidney81 on Dec 14, 2020 19:58:27 GMT 1
Post by dusty350 on Dec 14, 2020 20:06:00 GMT 1
Mutts sells the rubbers Chris, and Norbo I think. NKRacing usually has the Wiseco rubbers but they are expensive compared to the others. Martin at Madbiker too Dusty
Post by sidney81 on Dec 14, 2020 20:09:43 GMT 1
Mutts sells the rubbers Chris, and Norbo I think. NKRacing usually has the Wiseco rubbers but they are expensive compared to the others. Martin at Madbiker too Dusty hi dusty ,thank you ! That's a few options there I should be ok then π π
Post by jon on Dec 15, 2020 18:34:08 GMT 1
Iβd think carefully about a billet basket now itβs apart. Sure you can dress the notches but the more you do the noisier the. Lunch will be and it will wear quicker.
Another thing of note (although by the looks of the photos, you may already know) is the back plate is hardened an so an HSS countersink probably wonβt touch it. I had to use a countersink grinding stone.
Post by sidney81 on Dec 15, 2020 22:43:34 GMT 1
Iβd think carefully about a billet basket now itβs apart. Sure you can dress the notches but the more you do the noisier the. Lunch will be and it will wear quicker. Another thing of note (although by the looks of the photos, you may already know) is the back plate is hardened an so an HSS countersink probably wonβt touch it. I had to use a countersink grinding stone. Jon hi Jon the grooves look worse than they are ! You can only just feel them with your finger ! But I get what your saying ,I like to try and fix things if possible , and yes it is hard the back plate ,I'm going to take it to work and have a play with it ! At least if it dose go to pot I can fall back on a new one that option is there !we have lots of gear at work so I'm hoping I can do something ,will see !! π
Post by sidney81 on Dec 18, 2020 18:38:25 GMT 1
Got my crank back today from pj ! I should be happy but I'm not looks like it's been dropped or something was perfect when I sent it I even taped both ends up to protect the thread's!! ,And it comes back like this π‘,thumbs down from me unfortunately, hope it won't affect anything ?
Post by dusty350 on Dec 18, 2020 22:02:40 GMT 1
Hi Chris Have you spoken to Paul about it ? He's a good guy, I'm sure he would try to rectify any problems. Dusty
Post by 4l04ever on Dec 18, 2020 23:40:40 GMT 1
Got my crank back today from pj ! I should be happy but I'm not looks like it's been dropped or something was perfect when I sent it I even taped both ends up to protect the thread's!! ,And it comes back like this π‘,thumbs down from me unfortunately, hope it won't affect anything ? If it was dropped/damaged after it was adjusted, it may now be out of square, so may need rechecking. I know Paul Needham had one where the crank came back with the end of the thread damaged. He fitted it but had bad vibration, so had to strip engine and take it back to get sorted out.
Post by sidney81 on Dec 18, 2020 23:49:21 GMT 1
Hi Chris Have you spoken to Paul about it ? He's a good guy, I'm sure he would try to rectify any problems. Dusty hi no i got the crank when I was home from work after 5.30 and there now closed for x mass ,. Nearly Β£400 later I'm peed off ! Don't know if it's ok to fit ,? It's been cleaned up so I'm thinking it's been damaged while being worked on ,but they didn't tell me on the phone when wanting payment π‘
Post by tony2stroke on Dec 19, 2020 0:16:49 GMT 1
I would be livid!!! but I would also contact them first and be as nice as possible to resolve the issue, he has a very good rep, you have to give him a chance mate.
Post by sidney81 on Dec 19, 2020 0:30:20 GMT 1
I would be livid!!! but I would also contact them first and be as nice as possible to resolve the issue, he has a very good rep, you have to give him a chance mate. hi Tony oh definitely!! I will try get in contact in the morning,!! He has a great reputation from people I really trust and look up to ,I understand things go wrong accident's happen ! That's life ! I work in engineering and I know things go wrong sometimes! Just can't see why I wasn't told on the phone ! Now I'm not sure if it's ok to use ! I been waiting eagerly to get the crank back so I can rebuild it over x mass now I might not be able to ! That's a real bugger to me . But that's life I suppose! π
Post by steeley on Dec 19, 2020 6:03:12 GMT 1
Hi , i can understand you being a bit ticked off, but looking at the damage it looks to me it was done by the tooling that was used to press the big end pin out . I would set the crank up on v blocks and check the run out to see if it is ok . Then i would make sure the primary gear goes on . Oh, and phone the chap up about your concern he may get rid /scrap the particular mandrel used and post you a gizet/free be.
Post by sidney81 on Dec 19, 2020 8:11:49 GMT 1
Hi , i can understand you being a bit ticked off, but looking at the damage it looks to me it was done by the tooling that was used to press the big end pin out . I would set the crank up on v blocks and check the run out to see if it is ok . Then i would make sure the primary gear goes on . Oh, and phone the chap up about your concern he may get rid /scrap the particular mandrel used and post you a gizet/free be. hi steeley! I've not got the gear to check it correctly and if I'm honest I'm not confident enough to do it and be happy ! Surely they wouldn't send it out with a chance of it being out ? ,I will get in contact asap so I can try and move forward with it , I wanted to build the engine today ,thanks
Post by dusty350 on Dec 19, 2020 9:08:03 GMT 1
Hi Chris Paul is a member on here. I will send you a Pm mate Dusty
Post by tony2stroke on Dec 19, 2020 11:25:27 GMT 1
I would be livid!!! but I would also contact them first and be as nice as possible to resolve the issue, he has a very good rep, you have to give him a chance mate. hi Tony oh definitely!! I will try get in contact in the morning,!! He has a great reputation from people I really trust and look up to ,I understand things go wrong accident's happen ! That's life ! I work in engineering and I know things go wrong sometimes! Just can't see why I wasn't told on the phone ! Now I'm not sure if it's ok to use ! I been waiting eagerly to get the crank back so I can rebuild it over x mass now I might not be able to ! That's a real bugger to me . But that's life I suppose! π Its inconvenient for sure, but I would not just fit it without contact the guy, I would not be happy to fit it like that myself, looks like the damage you get when the key slips in the keyway to me.
Post by sidney81 on Dec 19, 2020 12:50:08 GMT 1
Hi everyone ,I've been in contact with Paul and were sorting it out he's us being very helpful so I feel happier now ,Chris
Post by steeley on Dec 19, 2020 18:02:08 GMT 1
Happy dayz As an aside are you missing the primary drive gear ?
Post by sidney81 on Dec 19, 2020 18:24:11 GMT 1
Happy dayz As an aside are you missing the primary drive gear ? hi bud no I have that π
