Post by bisto61 on Nov 10, 2019 22:41:38 GMT 1
Asking for advise on a couple of choices with my custom build. Firstly I started the project over 20 years ago and was building a lightweight Aluminium tubed frame for the road based on the geometry of a NWS sound of singles racer with clip ons and full fairing etc. Today I have had a rethink and want a naked machine and normal LC 350 look with raised handlebars more of a flat tracker look. Trouble is without a fairing I have removed the location I was planning for the remote radiator filler cap and the power valve servo which would have been fitted on the nose fairing on a fabricated mount. With out a fairing, and the LC 350 style headlamp now fitted to the stanchions betwen the yokes and with clocks fitted to the top yoke I have a no space. If I went for a LC rad which although bigger than the YPVS one it does away with the remote filler cap and then have to make a small modification to accommodate the bypass water pipe from the head, or I buy an aluminium YPVS rad and weld an aluminium filler cap boss to it and modify the top inlet at least this keeps the rad slim which is really what I want as space and clearance is tight. Does the N2/f2 have a slim rad with the filler welded on the rad itself? If I could work out how to post a few pictures on this forum it would help explain. Secondly in light of the space issues for the power valve servo, the fact that the power valves, the bushings the joiner are all completely worn out, the barrels are race tuned and one set of barrels is Fahron I believe and both need a rebore and new pistons,I was thinking of going back to LC days and fit a couple of AZ Quad parts standard Banshee cylinders and pistons am not looking to build the ultimate Yamaha but a nice machine to pop out on occasionally. What are anyone’s thoughts on these can they be tuned and fettled by and expert and who would that someone be?
will get some photos on this page asap if someone could assist in advising how to do it?
Looking forward to hearing your thoughts
All the best
Pb
Have since read about using flicker not sure about that one🤔
All the best
Pb
