mikeg
Post by mikeg on Oct 8, 2019 19:25:19 GMT 1
I’ve just put the rear wheel back onto the LC and tightened the wheel nut to the recommended torque 107NM. Tried spinning the wheel by hand and it is fairly stiff; no free wheeling. It also rubs on the back plate. I don’t remember it being like that before I took it off ? Mike
Post by marsbar350 on Oct 8, 2019 19:33:33 GMT 1
missed the spacer out maybe
mikeg
Post by mikeg on Oct 8, 2019 20:02:23 GMT 1
No the spacers have gone back in
Post by marsbar350 on Oct 8, 2019 20:13:55 GMT 1
is the brake been adjusted too much and binding
mikeg
Post by mikeg on Oct 8, 2019 20:21:56 GMT 1
No I haven’t refitted the rear brake yet. When bolt is finger tight it spins fine.
Post by andymoore on Oct 8, 2019 20:29:29 GMT 1
Are the fins damaged in the wheel
Post by Tobyjugs on Oct 8, 2019 20:35:12 GMT 1
Did you strip the wheel? There is a spacer between the two wheel bearings.
mikeg
Post by mikeg on Oct 8, 2019 20:41:38 GMT 1
Andymoore, not sure what you mean by fins ?
Post by 4l04ever on Oct 8, 2019 20:49:12 GMT 1
Post by 4l04ever on Oct 8, 2019 20:52:36 GMT 1
Maybe the bearings are not fully seated.
Post by andymoore on Oct 8, 2019 21:48:27 GMT 1
Back plate and wheel have fins that interlock to stop water and muck getting in the drum
Post by madmick on Oct 8, 2019 22:19:42 GMT 1
Sounds like a definite spacer problem to me 🤔
M.M.
Post by JonW on Oct 9, 2019 9:38:57 GMT 1
Check the captive spacer thats inside the brake backplate, it can get work out if things are not working properly. Ive seen them go missing completely as well. That will allow the backplate to contact the wheel and make this noise.
