bigal
Post by bigal on Sept 14, 2019 16:45:19 GMT 1
With me not been an RD expert could someone tell me if the above coils are a single coil unit with two leads coming out or 2 Separate coils with a lead each
I only ask as I seem to be getting a misfire at the bottom end and when I lifted the tank off I noticed I only had a singular coil pack with 2 leads 🤔
Al
Post by reedpete on Sept 14, 2019 17:03:27 GMT 1
Single coil , two leads. Runs what’s called a wasted spark system.
Post by 4ce on Sept 14, 2019 17:30:07 GMT 1
Think it`s the same as LC coil
Post by reedpete on Sept 14, 2019 18:59:16 GMT 1
Same plug and functionally same...but different size
bigal
Post by bigal on Sept 15, 2019 11:17:41 GMT 1
Thanks
Any ideas on the misfire on the bottom end it goes like stink on the top end
I thought it might be the pilot jets but muttsnuts had the carbs ?
Post by muttsnuts on Sept 15, 2019 11:30:15 GMT 1
could be the stator, same specs as an LC stator, so testing results should be the same, probably low side coils or maybe the pickup, worth trying first anyway
bigal
Post by bigal on Sept 15, 2019 14:12:48 GMT 1
I think it might be having a trip to Malton Dave👍
bigal
Post by bigal on Sept 21, 2019 10:27:14 GMT 1
could be the stator, same specs as an LC stator, so testing results should be the same, probably low side coils or maybe the pickup, worth trying first anyway What readings should I be getting ?
