Post by headcoats on Sept 11, 2019 13:23:17 GMT 1
Running pod filters too
I have put in 160 mains and 45 pilots but what have other folks run ? On my red LC I have 152 mains and 42 pilots on pods but is the Athena a bit more flowing or less !
Post by muttsnuts on Sept 12, 2019 13:41:35 GMT 1
I'd say 160/45 is too much, but I can check when I get 5 mins for you on my dyno sheets for similar set ups
Post by headcoats on Sept 12, 2019 14:00:35 GMT 1
Yes Please , that would be good
Had a feeling a bit rich on the main but was going to start rich
Hasn't been started yet so a few weeks to mull it over
Post by mick858 on Sept 12, 2019 20:55:51 GMT 1
Athena 392, Alonze pipes, 28mm PWKs. 135 mains, 58 pilots, N68a needles.
HTH Mick
Post by wallcraft on Sept 12, 2019 22:04:19 GMT 1
Athena 392, Alonze pipes, 28mm PWKs. 135 mains, 58 pilots, N68a needles. HTH Mick Take it that's with the air box on? Mark.
Post by mick858 on Sept 12, 2019 22:11:06 GMT 1
Sorry, should also have said it's with Ramair foam pods.
Post by muttsnuts on Sept 13, 2019 17:41:42 GMT 1
Athena 392, Alonze pipes, 28mm PWKs. 135 mains, 58 pilots, N68a needles. HTH Mick I set Micks up, and that is the jetting I was going to check, so there you go, its a good starting point, just bear in mind his is set for more mid range/bottom end so the pipes ect are more set towards that, hence why the pilots are so big
