Post by 4ce on Sept 10, 2019 20:57:10 GMT 1
Does anyone know if 2R9 400F emulsion tubes and needles are the same as 4L0 350LC ones?
400 needles are 522-14116-01-00 LC350 needles are 4L0-14116-01-00
400 tubes are 360-14141-42-00 LC350 tubes are 4L0-14141-42-00
Post by shaunthe2nd on Sept 11, 2019 23:07:14 GMT 1
Yam part numbers so unlikley. Try speaking to Allens in Nottingham, very knowledgeable if you get the right fella.
Post by 4ce on Sept 12, 2019 10:51:26 GMT 1
Thanks, will call Allens.
Post by muttsnuts on Sept 12, 2019 13:32:20 GMT 1
no they are completely different
The 400E/F needle is a 5J6 (NLA) and the 350LC is a 5K1
The LC needle jet is a 345-p2 (well for the later carb), but lets not split hairs, it is a non-shielded jet, the 400 one is shielded, iirc its a 284-O8
HTH
Post by jon on Sept 12, 2019 18:00:27 GMT 1
I think I have a set of brand new RD400 needle jets I’d sell.
I’ll dig them out if you want?
Post by 4ce on Sept 12, 2019 18:19:02 GMT 1
Thanks for your wisdom Mr Nutts. Will be visiting you for some more hopefully soon. P.M. sent Jon
Post by muttsnuts on Sept 15, 2019 11:31:07 GMT 1
if Jon don't have any, I do for sure
Post by 4ce on Sept 20, 2019 19:19:42 GMT 1
Got in touch with Allens to try and source some needles. Dave at Allens says the 5L03 needle is NLA superseded by either a5L08 or a 5L01 but he`s not sure which one fits the Emulsion tube. He says it`s a case of suck it and see. Anyone had anything to with these. Help and advice gratefully taken on board. Nigel
Post by Ozhammer on Sept 24, 2019 0:45:43 GMT 1
The only alternative to the 5J6 needles that I know of is the Cruzinimage ones, which people have apparently had good results using.
As for the emulsion tubes, as has already been mentioned, these are the 284-08 type, which I may have a spare pair of if you get stuck sourcing locally.
Another alternative might be to have your carbs modded by Spa Motorcycles. I have a pair of those fitted on my 400G and it goes really well after some set up work.
HTH
Post by 4ce on Sept 24, 2019 21:21:04 GMT 1
The only alternative to the 5J6 needles that I know of is the Cruzinimage ones, which people have apparently had good results using. As for the emulsion tubes, as has already been mentioned, these are the 284-08 type, which I may have a spare pair of if you get stuck sourcing locally. Another alternative might be to have your carbs modded by Spa Motorcycles. I have a pair of those fitted on my 400G and it goes really well after some set up work. HTH Where can I get Cruzinimage needles? Nigel
Post by 4ce on Sept 24, 2019 21:41:45 GMT 1
Found their website and emailed them Thanks Nigel.
Post by Norbo on Oct 15, 2019 11:03:43 GMT 1
I have needles and emulation tubes so if you need any i have loads for all Air coolers including the E/F ones .
