Post by perazzi350 on Aug 29, 2019 16:45:35 GMT 1
Hi guys new on here just bought lc 350 hybrid, the one with the nasty red seat...i think you know which one it is !! lots to do to it so hope for some much needed help
Post by tipfinchy on Aug 29, 2019 17:04:13 GMT 1
welcome you have found a good place you can get loads of help if you post photos
Post by perazzi350 on Aug 29, 2019 17:25:26 GMT 1
OK thanks for that,just have to work out how to do it,computer is not my strong point.
Post by stusco on Aug 29, 2019 17:35:01 GMT 1
I think Tapatalk is the easiest for posting pictures
Post by oldbritguy on Aug 29, 2019 17:36:11 GMT 1
Hi and welcome to the forum.
Post by dusty350 on Aug 29, 2019 21:14:01 GMT 1
Hi Welcome to the forum Dusty
Post by 4l04ever on Aug 29, 2019 22:21:49 GMT 1
Welcome in :-)
Post by rigga on Aug 29, 2019 22:43:25 GMT 1
Welcome aboard
Post by perazzi350 on Aug 30, 2019 22:21:09 GMT 1
Any one heard or seen a 250 LC OVX243V I bought this bike new in July 1980, threw it up the road,kept it a year then gave the bike with the HP book to a mate to carry wondered if it was still on the road?
Post by 4l04ever on Aug 30, 2019 23:19:24 GMT 1
Post by perazzi350 on Sept 2, 2019 20:00:16 GMT 1
Here is a photo
Post by perazzi350 on Sept 2, 2019 20:02:57 GMT 1
Think I may have a problem, I just noticed the chain has been rubbing on the frame so more investigation needed!
Post by tipfinchy on Sept 2, 2019 22:05:44 GMT 1
I like that bike hopefully someone (who knows far more than I ) will be along to ask you questions to help solve your bothers let me know if you want to sell the seat mart
Post by dusty350 on Sept 2, 2019 22:05:51 GMT 1
I thought Andrew M had decided to keep this bike, but obviously not ! There is a thread in this resto section - just look for his name and you'll find it. He mentions the wrong offset sprocket issue that's allowed the chain to rub the frame. Should be a relatively easy fix to get the run right. Good luck Dusty
Post by dusty350 on Sept 2, 2019 22:07:20 GMT 1
Post by perazzi350 on Sept 2, 2019 22:14:22 GMT 1
thanks Dusty, I will have a look just had a chat to Rob he gave me some very useful information on how to align and check chain run, job for weekend I think
Post by perazzi350 on Sept 2, 2019 22:16:17 GMT 1
I have a new seat guys this ones going in the ugly bin..
Post by shaunthe2nd on Sept 2, 2019 22:23:23 GMT 1
Welcome in. Hope you have better luck with that bike than the last owner. The consensus was to lose the seat and the oversize LC logos!
Hope you get it sorted and enjoy riding it.
Post by Dangerous on Sept 3, 2019 8:04:23 GMT 1
Welcome to the forum, nice bike👍
Post by 4l04ever on Sept 3, 2019 15:56:11 GMT 1
I think the seat was bringing all the bad luck with this bike... :-)
Post by Tobyjugs on Sept 3, 2019 17:46:38 GMT 1
Post by abar121 on Sept 3, 2019 18:57:30 GMT 1
Welcome and good decision on the seat!
It looks like something off a minimoto!
Post by veg on Sept 3, 2019 19:08:21 GMT 1
Loads of potential welcome 👍
Post by jon on Sept 3, 2019 20:26:50 GMT 1
What width of rear tyre is fitted?
Post by perazzi350 on Sept 3, 2019 21:28:46 GMT 1
Hi Jon its got a 150 wide tire on it, had a quick look tonight and im not sure if all is correct on the swinging arm.need more time to investigate.Looks like arm is not central but as I said.need to check this properly and that wheels are inline first. The chain has definitely hit the tire on that side at some point,just from looking it looks like the wheel is closer to swinging arm on one side than the other,I dont know what spacers etc should be on the wheel as it has a brake carrier which i dont know is standard as it has a small brembo caliper.If anyone knows what size the the carriers and spacers are it would be of great help. cheers steve
Post by perazzi350 on Sept 3, 2019 21:30:39 GMT 1
Its the rgv rear wheel and swinging arm
Post by jon on Sept 3, 2019 22:06:02 GMT 1
It’s a simple case of maths.
The LC is about 201mm wide at the swingarm.
With a 150 tyre, if the wheel is central then there should be 25.5mm or so each side.
A 520 chain is about 18mm wide.
So assuming you have everything set up perfectly there may be 3.75mm clearance between the tyre and frame with the chain.
And that’s an ideal setup.
If the chain is not in perfect adjustment it can easily move sidewards and hit the tyre or frame.
That is exactly why my latest LC, and indeed many in the past has been spread wider.
Post by perazzi350 on Sept 8, 2019 17:38:12 GMT 1
Hi guys decided to remove swinging arm today, as soon as l slackened the nut it dropped on disc side when I removed it the spindle fit is really loose on this side it looks like it needs a bush or something, chain side is nice snug fit, the central bush or bushes just slide up and down.. is this right? Advise please first attempt at this!
Post by perazzi350 on Sept 8, 2019 17:42:03 GMT 1
Post by perazzi350 on Sept 8, 2019 17:45:08 GMT 1
