Post by robertson83 on Jul 12, 2019 21:52:35 GMT 1
Hi guys, looking for some info on power valve wiring. I have a zeel pcdi 10vt and have wired to the diagram given by zeel, the valves do their clean cycle but when the bikes ticking over it doesn't return to the closed position, on closer inspection it appears that the servo motor is turning the opposite way that it should and when I swap the cables round it pulls the right way, I am also using an electrex world generator that has been wired exactly to the diagram given. any help would be greatly appreciated as I am turning bald very quickly
Post by 4l04ever on Jul 12, 2019 22:14:24 GMT 1
Where are you located, as there maybe someone local who can give you a hand?
Post by robertson83 on Jul 12, 2019 22:40:11 GMT 1
I'm in the forest of dean, cheers
Post by robertson83 on Jul 13, 2019 12:01:43 GMT 1
Ok so got a little further, after a bit of digging I found an old post saying the zeel box starts on the closed position and now that side of things is working after setting the max and minimum opening of the valves however they still don't open when the bike revs, any ideas? Cheers
Post by robertson83 on Jul 13, 2019 22:28:44 GMT 1
Can anyone give me contact details for a guy in Dudley called Dave Reynolds, cheers
Post by stusco on Jul 14, 2019 14:54:46 GMT 1
I have the same zeel to set the pv I turn on the ignition when it turns to fully open I cut the ignition and adjust the cables so a 4mm drill fits in the hole job done
Post by robertson83 on Jul 14, 2019 21:10:20 GMT 1
cheers, think I have sorted the adjustment now but the valves are not opening when the bike revs, any ideas?
Post by robertson83 on Jul 14, 2019 22:11:14 GMT 1
also when the handheld programmer is plugged in it isn't picking up revs
Post by marrcel on Jul 15, 2019 6:41:45 GMT 1
cheers, think I have sorted the adjustment now but the valves are not opening when the bike revs, any ideas? They should open at least above 7k rpm
Post by robertson83 on Jul 15, 2019 7:58:07 GMT 1
Is there a setting on the zeel that I'm missing or somthing?
Post by bare on Jul 15, 2019 18:00:54 GMT 1
# possibles here: 1) you've got it incorrectly wired 2) The Cables are incorrectly installed 3) the zeel unit is broken Email Zeel for help.
Post by robertson83 on Jul 15, 2019 18:40:13 GMT 1
I was getting confused as didn't realise that the position for power valves with the zeel starts at closed, the cables are on correctly and it is wired to the servo to the letter, also the valves do their clean cycle on power up so can't be sure if it is the zeel box at fault, have emailed zeel but no reply yet
Post by stusco on Jul 15, 2019 19:14:19 GMT 1
He’s not replied to me either but I got a automated reply say he was away until 14/7/19
Post by robertson83 on Jul 15, 2019 20:07:35 GMT 1
That will probably be it then, did you have any problems like this with your zeel?
Post by gary1968 on Dec 12, 2019 20:14:46 GMT 1
Sorry if this sounds stupid but what is zeel is it a after market control box to work the powervalve thanks Gary
Post by stusco on Dec 12, 2019 20:19:15 GMT 1
Sorry if this sounds stupid but what is zeel is it a after market control box to work the powervalve thanks Gary zeeltronic.com/
Dave B
Post by Dave B on Dec 13, 2019 10:54:21 GMT 1
If the hand held does not show the RPM, then the chances are that the servo controller is not receiving the signal from the pulse coil either. On the other hand, the engine runs, so the pulse coil must be working. If the servo controller does not know the RPM, then it will not open the valve. That connection from the generator to the Zeel is the one you need to concentrate on.
