tlmark
Post by tlmark on Jun 14, 2019 16:13:47 GMT 1
Spent most of this week between monsoon downpoors working on stripping the paint off the side cases, and fixing the road rash on the clutch side.
I used a rattle can engine enamel and they came out pretty good considering.
not show perfect but good enough for me.
I need to make my mind up about if to use the stock plastic disc covers or go with
Norbos nice shiny ones.
The bodywork is off to the painter at the end of next week.
and after the news that the guy who makes the LC club looms has had a bad accident
I've bought the one from Alan electrics.
It's all moving along
Post by dusty350 on Jun 14, 2019 19:52:26 GMT 1
I'd be interested in what you think regards the loom you are getting. Still need one for my Lc hybrid, and did contemplate the ebay loom. Cases look good Norbo's bling covers are nice - I would !! Dusty
tlmark
Post by tlmark on Jun 17, 2019 11:21:04 GMT 1
Well the loom has arrived
tlmark
Post by tlmark on Jul 1, 2019 12:47:55 GMT 1
Been away on my Hols so not much has been done since, but today I picked up my head and barrels and new crank from Taymars
Also my painter left a message that he needs the rolling chassis to make all the lines match up when fitted so I gotta sort that out this week too.
tlmark
Post by tlmark on Jul 2, 2019 21:43:23 GMT 1
So dropped the rolling chassis of to my painter today and had my first glimpse of the tank I'm stupidly excited
my painter only has the side panels to finish so I'm hoping it'll be done by the weekend.
Post by lolly on Jul 3, 2019 9:41:46 GMT 1
who did your seat ? Looks a really good job ; I need mine doing .
tlmark
Post by tlmark on Jul 3, 2019 12:23:57 GMT 1
who did your seat ? Looks a really good job ; I need mine doing . Thanks I did it myself you’ll need a electric stapler and it wasn’t anywhere near as daunting as you might expect and very satisfying.
Post by Mr Kipling on Jul 3, 2019 13:20:39 GMT 1
coming along nicely keep up the good work...
Post by lolly on Jul 3, 2019 14:06:22 GMT 1
who did your seat ? Looks a really good job ; I need mine doing . Thanks I did it myself you’ll need a electric stapler and it wasn’t anywhere near as daunting as you might expect and very satisfying. where did you get the cover ?
Post by 4l04ever on Jul 3, 2019 14:13:43 GMT 1
Are you going to file the tangs off the pistons, as they are YPVS pistons in LC cylinders??? Worth doing :-)
tlmark
Post by tlmark on Jul 3, 2019 16:41:23 GMT 1
Thanks I did it myself you’ll need a electric stapler and it wasn’t anywhere near as daunting as you might expect and very satisfying. where did you get the cover ?Ebat Ebay I have looked but its not in my history anymore, sorry it was £30.00
tlmark
Post by tlmark on Jul 3, 2019 16:43:00 GMT 1
Are you going to file the tangs off the pistons, as they are YPVS pistons in LC cylinders??? Worth doing :-)I I've read that some of you guy do that whats the thinking behind doing it?
tlmark
Post by tlmark on Jul 3, 2019 16:57:45 GMT 1
Spent most of the day putting the gearbox into the new cases
and lapping the flywheel on the crank
then took my old BSA out for a ride in the sun
she's great fun to ride once you get you head back into the gears being on the right and upside down
Post by jon on Jul 3, 2019 20:10:32 GMT 1
Are you going to file the tangs off the pistons, as they are YPVS pistons in LC cylinders??? Worth doing :-)I I've read that some of you guy do that whats the thinking behind doing it? YPVS barrels have two inlet ports and a bridge in the middle where the tang runs. Having the tang supports the piston more in this case. An LC has no support here. The worry is the tang will catch the bottom of the inlet port and smash the bottom off the piston. Some say there is no need to remove the tang, and have had no problem. I suspect that on a fresh bore there is no rock, so it OK. A worn barrel is a different thing. My thinking is why not just in case? It’s easy for piece of mind. Jon
Post by 4l04ever on Jul 3, 2019 23:14:57 GMT 1
I have seen two pistons with the bottom damaged from the tang hitting the port, so I file the tangs off now.
tlmark
Post by tlmark on Jul 6, 2019 12:53:04 GMT 1
Lapping the rotor to the new crank jeez what a slow tedious job To be fair my rotor is pretty bad
tlmark
Post by tlmark on Jul 6, 2019 20:55:54 GMT 1
Bottom end built. and even 30 years later it still cost 2p to do the crank nut up
Post by jon on Jul 7, 2019 9:03:08 GMT 1
Pre 1992 2p I hope.
Post by dusty350 on Jul 7, 2019 10:05:44 GMT 1
Engine build is looking good Mark Not far off now ! Dusty
tlmark
Post by tlmark on Jul 8, 2019 21:44:15 GMT 1
Got the finished paintwork back today very happy with how that has come out. painted the head and barrels yesterday. And spotted This, obviously, Bond rode an LC
Post by doohanno1 on Jul 8, 2019 22:13:22 GMT 1
My name is Bond..
ThreeBond...
I rode a few lc's with ejector seats..
tlmark
Post by tlmark on Jul 9, 2019 9:32:03 GMT 1
I was shaken and stirred a few times too :-)
tlmark
Post by tlmark on Jul 10, 2019 19:20:50 GMT 1
The only issue I've encountered with the new loom is that the fuse box is a lot thicker so it fouls on the side panel.
I guess this is due to it using modern blade type fuses.
I tried several different places but the best solution I found was to cut off the 4 connector block clips under the voltage rectifier.
tlmark
Post by tlmark on Jul 22, 2019 12:02:46 GMT 1
Quick question do you guys think the old steel reeds would need replacing?
In my ownership it's never had them changed, and can you still get the stock ones?
Or is there, like a lot of stuff modern better fitments?
tlmark
Post by tlmark on Jul 27, 2019 15:47:05 GMT 1
More progress some good so not so good I have all the electrics (not including ingition side) but I do have a problem with the rear light so some fault finding to do on that.
I tried to do some polishing of bits and bobs on the motor, and some came out better than others,
but I'm pleased with the overall look of the motor. Norbo's head and engine bolt kits add a bit of bling
I think I might need take a few mm off of the bottom hose to get the fit I want.
Hoping to have the carbs and exhausts on by the end of the weekend
Post by donkeychomp on Jul 27, 2019 22:39:24 GMT 1
Reeds look fine to me. Engine is stunning...
Post by bid on Jul 28, 2019 13:07:37 GMT 1
Great job, looks spanking😉
tlmark
Post by tlmark on Jul 28, 2019 15:33:19 GMT 1
I couldn't wait to put the pipes on to have a look at the bike as a whole
she's sitting a little tail low as the the new shock needs some pre-load winding in to have her sitting
right
The paint work i'm very happy with, mars bar speed blocks
Post by LC_BOTT on Jul 28, 2019 16:05:38 GMT 1
Lovely job you've done there, great finish overall, should be pleased with that not too keen on the paintjob myself, sorry.
tlmark
Post by tlmark on Jul 29, 2019 7:34:08 GMT 1
Thanks, custom paint is personal thing so I understand
