Post by sidney81 on Feb 16, 2023 23:04:26 GMT 1
Nice mod Al 👌👌
Post by alankelly on Feb 16, 2023 23:23:10 GMT 1
Thanks guys for the 👍👍
Next on the list for modification of the engine internals will be the modified shift star and the bearing upgrade on the shift star stopper arm👍👍
Post by alankelly on Mar 1, 2023 18:53:10 GMT 1
Hi all Still progressing with bits and bobs for the build. As I have started my engine build started to look around a set of cylinder head bolts for the A/C barrels. A few on EBay but all very secondhand so decided to make some myself. Bought 8 stainless M14 SHC bolts and modified them to suit on the lathe. Not for those that want originality, but nothing original about this project🤣 Catch up again soon Best wishes Al
Post by sidney81 on Mar 1, 2023 21:59:32 GMT 1
Beautiful work al 😎💪💪
Post by donkeychomp on Mar 1, 2023 22:42:06 GMT 1
I may have said this before but he's a clever lad isn't he?
Post by shandyboy on Mar 1, 2023 22:44:31 GMT 1
looking Good Al, and like the outside of the box thinking lol
Post by charles13 on Mar 2, 2023 0:52:10 GMT 1
Hi all Still progressing with bits and bobs for the build. As I have started my engine build started to look around a set of cylinder head bolts for the A/C barrels. A few on EBay but all very secondhand so decided to make some myself. Bought 8 stainless M14 SHC bolts and modified them to suit on the lathe. Not for those that want originality, but nothing original about this project🤣 Catch up again soon Best wishes Al Wow! This site never stops amazing me
Post by JonW on Mar 2, 2023 1:36:39 GMT 1
Ohh those came out really nice Al, great work!
Post by Yogi on Mar 2, 2023 8:54:32 GMT 1
Superb work Al 👍 I’ve got these lying around if ya need them 😉 Gratis to you of course Stainless,originally for Lc head bolts but no threads cut in them Cheers Matt 🐻
Post by alankelly on Mar 2, 2023 10:50:02 GMT 1
Been a while since I have added some nice pics of the project outside to the thread Going to look a Bobby Dazzler especially if I can get the pipes made and fitted later this year funds permitting🤣
Post by donkeychomp on Mar 2, 2023 22:23:18 GMT 1
Those 2 bolts holding the front caliper on...mine are rusty! So I'm off to get some stainless ones. Would you like a pair Al?
Post by alankelly on Mar 9, 2023 19:02:09 GMT 1
Another job done👍 Needed to adjust the front disk offset as running a KTM wheel in a Cagiva Mito front forks and single disc / Brembo caliper Lathe has not got a big enough “swing” to accommodate a 17” wheel so did it on the mill instead👍 Lovely chubley and another “job to do” ticked off on the project Catch up again soon Al
Post by alankelly on Mar 9, 2023 20:08:39 GMT 1
Perfect😎
Post by donkeychomp on Mar 9, 2023 22:16:55 GMT 1
Missing a bolt there Al. I still haven't gone to get some new ones, would you like a pair?
Post by alankelly on Mar 9, 2023 22:44:07 GMT 1
Missing a bolt there Al. I still haven't gone to get some new ones, would you like a pair? Alex Hi Alex If that is ok but will take a look at work tomorrow also see what we have in stock? Best wishes Al
Post by donkeychomp on Mar 9, 2023 23:08:54 GMT 1
I'm going to get them tomorrow so I'll pop them in the post Al. Glad I could help!!
Post by donkeychomp on Mar 10, 2023 16:06:35 GMT 1
Posted Alex
Post by alankelly on Mar 10, 2023 16:09:30 GMT 1
Posted Alex Hi Alex Thank you👍 Best wishes Al
Post by lcmarky on Mar 10, 2023 17:22:50 GMT 1
Another job done👍 Needed to adjust the front disk offset as running a KTM wheel in a Cagiva Mito front forks and single disc / Brembo caliper Lathe has not got a big enough “swing” to accommodate a 17” wheel so did it on the mill instead👍 Lovely chubley and another “job to do” ticked off on the project Catch up again soon Al Who needs a rotary table!
Post by lcmarky on Mar 10, 2023 17:24:19 GMT 1
& looks like a Bridgeport quill to me - reminds me of my apprenticeship days.
Post by alankelly on Mar 14, 2023 22:18:41 GMT 1
Having the ability to design a model and then 3d print a test part for testing makes this project so much easier👍 As I am still awaiting my frame guy (as he is snowed under at the moment) decided to design a mounting plate / adaptor to allow me mock up my rear master cylinder mounting on the rear set assembly Looks ideal and later can then commit to an aluminium adaptor to mount the master cylinder now I have the final design Best wishes Al
Post by tdrpete on Mar 15, 2023 13:29:21 GMT 1
Never ceases to amaze me the quality of workmanship you guys churn out. Brilliant job well done cant wait to see her finished.
Post by alankelly on Apr 4, 2023 13:08:52 GMT 1
Hi all Well that’s her all stripped down as off to frame guy this Thursday for the required frame changes Once done that will be a big step foward with the build Catch up again soon and ride safe Best wishes Al
Post by mouse on Apr 5, 2023 10:57:15 GMT 1
Glad to see more progress on this!
Mouse
Post by alankelly on Apr 10, 2023 16:58:42 GMT 1
Hi all and hope you had a good Easter. Ok while the frame is away being modified started to source everything for the fuel / inlet assembly Managed to find a pair of 4L01 carbs, and also got a set of Reed cages fitted with Hitec carbon Reeds and sourced a link pipe thanks to Rob. Also as no airbox will be used, the setup will be fitted with Ramair filter pods. Got a few small carb items on order from Norbo to finish off the assembly, and it will want rejetting to suit, but another part of Tigcraft jigsaw hopefully sorted👍
Post by alankelly on Apr 14, 2023 20:00:34 GMT 1
As frame is away for a while so not much to do so thought might as well give the carbs I sourced last week a once over So time to give them some ultrasonic bath time, “clean behind my balls” (will tap the hole to accept a m5 grub screw rather than put the original balls back) and replace the cloudy carb windows with clear replacement ones👍 Should be as good as new once finished👍 Have a good weekend all Best wishes Al
Post by JonW on Apr 15, 2023 2:07:48 GMT 1
Great progress to have this done Al, I must grab some windows off you at some point as this is a great job to have done on old carbs, along with the behind ball cleaning.
{Thinking} Might be time for a 'Secondary carb overhaul kit' for those wanting this level of refresh and not already more than conversant with the job (as many of us are of course); Perhaps, grub screws and windows and maybe a tap. One for Norbo?
Post by alankelly on Apr 19, 2023 17:52:34 GMT 1
Well that’s the carbs pretty well finished for this project Full strip, ultrasonic bath and rebuild and all the minor “missing parts” replaced with new from Norbo (other than the choke link pipe) Brass balls replaced with short m5 grub screws Cloudy sync windows replaced👍 Now fitted with 27.5 pilots and larger 400 mains as a rough base point jetting set up to account for the foam pod filters Will now put away till a later date when the frame is back and the engine actually fits in the frame Then next stage exhausts👍👍😉😉 Best wishes and ride safe all Al
Post by shaunthe2nd on Apr 19, 2023 18:12:21 GMT 1
Some great progress Al and a good read. Keep it coming!
Post by alankelly on Jun 25, 2023 14:47:21 GMT 1
Been a while since posting anything Frame still away at my frame guy but he is semi retired and not chased him as other stuff going on. But my bespoke rear caliper bracket in aluminium is now done. Fits ok too in the rear swinger👍 Only a small part of the overall project 😔but another “bit” of the puzzle solved and completed.😉 Hopefully next post will be some pics of the modified frame back. Catch up soon Best wishes Al
