Post by veg on Nov 30, 2018 16:54:50 GMT 1
Just a quicky previously when I have fitted new ht leads I have stripped the wire down to the copper core then crimped onto that with these ht leads they have an outer then a fibre then a v thin wire do I crimp to the thin wire or does the outer fibre conduct as well? Thanks
Post by LC_BOTT on Nov 30, 2018 17:41:26 GMT 1
I fitted some Taylor leads to my KR (not sure if these are the same?) I'm sure I just pulled all the stripped-back inner core, back over the outer HT lead, and crimped the whole lot with the supplied plug connector. The inner core is very very thin from memory?
Post by veg on Nov 30, 2018 18:21:50 GMT 1
I fitted some Taylor leads to my KR (not sure if these are the same?) I'm sure I just pulled all the stripped-back inner core, back over the outer HT lead, and crimped the whole lot with the supplied plug connector. The inner core is very very thin from memory? Massively thin and almost impossible to double over
Post by yamark on Nov 30, 2018 18:35:51 GMT 1
As LC_bott describes, that's how I fitted my leads to the crimp connectors on the LC triple. It might be less hassle to change the type of HT lead, to get a thick copper core. Easier to screw in the plug caps as well
Post by JonW on Dec 1, 2018 12:50:59 GMT 1
I bought a meter of nice old school lead from ebay that was sold for brit bike restores. Worked a treat.
