Post by veg on Nov 28, 2018 20:37:53 GMT 1
Anyone created a wiring diagram for electronic speedo and tach of a 4lo? Thanks
Post by JonW on Nov 28, 2018 22:52:59 GMT 1
Nope, but if its a Koso then I expect that the tach will run off one of the white wires from the stator. I ran mine like that on my Koso Dual EGT dash on advice from Koso America, who I bought the instruments off.
The rest is easy, most need just need a +12v, switched 12v, dash lights, and earth.
Post by Tobyjugs on Nov 28, 2018 23:02:05 GMT 1
If i remember rightly the the tacho wire is blue/yellow and can be taped directly to the coil feed or spiral wound around one of the HT leads.
Post by badger1 on Nov 28, 2018 23:20:06 GMT 1
My koso tacho worked by connecting to the coil feed but once running it would become irattic and didn’t seam to be very responsive. I was advised to fit a koso filter which I did. This connects to one of the ht leads or a coil feed, works spot on now.
Post by Tobyjugs on Nov 29, 2018 6:23:38 GMT 1
My koso tacho worked by connecting to the coil feed but once running it would become irattic and didn’t seam to be very responsive. I was advised to fit a koso filter which I did. This connects to one of the ht leads or a coil feed, works spot on now. Very true but i think it depends on which unit you buy. If the clocks were playing up i changed the plug to a resistor type. Most of the clocks i fitted were for 50cc bikes.
