Post by Bakker RD on Nov 1, 2018 22:11:19 GMT 1
Hello,
I'm a newbe on this forum and have signed up because I might have an interesting bike to show to the two stroke community.
The other thing is that this special bike refuses to fire up and I hope the collective knowledge on this forum can push me in the right direction.
This is the story: 10 years ago I was able to buy a rough but very two stroke special. An RD350 31k with an alloy chassis made by dutch chassis genius Nico Bakker. Famous for its racing chassis made for several 500cc riders in the 70's and early 80's. In 1983 Nico Bakker received an order from a Japonese Yamaha dealer to make 50 alloy versions of the stock steel frame. Not all 50 were build and a few stayed in Europe. The chassis of my bike stayed in Holland and was registered in 1985 as a road bike but was fitted with a lot of special parts like mag PVM wheels, alloy fuel tank, WiWo magnesium 4 pot brakes with cast iron vented disk, magnesium tripple clamps cast by PVM for Bakker. Spondon type mechanical anti dive, magnesium Marzocchi 38mm racing forks, a White Power rear shock, Motometer temp gauge and a scitzu tacho.
It was running when I bought it but poorly and with a cracked exhaust.
I decided to fix the engine first but discovered nothing wrong there. Beautifully reworked cilinders and pistons which were almost new. The last owner had made a c**k-up by fitting a stock base gasket which covered up 50% of the enlarged transfer ports messing up the flow so I reworked that but otherwise it was fine. Only thing I changed was the squish which I set to exactly 1mm by skimming the head.
Afterwords I repaired the exhaust and started to work on detailing the bike. last owner had fitted a bicycle computer as a speedo and toggle swiches on the handlebars which had to come off. I found period correct switchgear with all switches in one unit so on the right side I only needed a kill switch. I found a small mechanical speedo reading to 220kph and noticed I lost interest in the wiring part so switched to the cycle parts which I had soda blasted and resprayed. Djuz fasteners and a batch of low head allen bolts were bought and I'm not sure what happened then but in the middle of this work it was parked under a tarpaulin only to be removed a month ago.
With fresh inspiration I finished all the wiring and fitted a zeeltronic PCDI 10VT programmable ignition. Iridium plugs, Vforce 4 reeds, Dynatek mini 3ohm coil and had the flywheel lightened and rebalanced. The Mikuni VM34 carburators were cleaned, float height set (were both way off (15 instead of the correct 22mm) and I made a note of the current jetting (55 pilot and 310 main, 6F9 needle with the clip in the middle groove. Air screw 1.5 turns out).
But it won't start... There is a spark and there is fuel. It has enough compression but not one puff to prove I'm close. I have set the static angle on the zeel to 34deg and have programmed a flat 20deg curve to check the compensation but nothing happens.
Can anyone give some advice?
many thanks,
William
thumbnail_IMG_6040 by William Van der sman, on Flickr
5D27ADA8-DC82-4693-B204-0B771A7377B7 by William Van der sman, on Flickr
46042299-6BE3-478B-9D95-C8C317D084E5 by William Van der sman, on Flickr
many thanks,
William
