Post by abar121 on Mar 23, 2019 17:49:36 GMT 1
Post by marrcel on Mar 24, 2019 16:26:38 GMT 1
No cables my friend. Speedo pickup and tachosignal from the primairy coil side. The orange wire from the cdi. I did put a 220ohm resistor in series with the orange wire. And a 1uF capacitor at the tach to earth. This a low pass filter. May be not nescesary. The gear and temp indicator i do not use.
Post by abar121 on Mar 24, 2019 16:31:57 GMT 1
Thanks mate. The pictures from that link are confusing!
denver
Post by denver on Jan 18, 2020 17:45:25 GMT 1
Cool, I haven't thought about putting a more modern clock in the ol' LC housings. I dig it
Post by tony2stroke on Jan 18, 2020 18:39:59 GMT 1
Post by JonW on Jan 20, 2020 22:45:11 GMT 1
Tony those defo look like my one.
Post by tony2stroke on Jan 20, 2020 23:39:10 GMT 1
Tony those defo look like my one. I had another look last night and found a digital tacho, pricey but nice and should fit in the other side. www.ebay.co.uk/itm/85mm-EVO-DIGITAL-Tachometer-Gauge-LED-BLUE-RED-GREEN-WHITE-With-Peak-Warning/361819558038Also this cool looking thing, 6 in 1 you can use temp gauge, volt meter, gps speedo, digital tacho, milometer, trip meter, hour meter, you may even be able to use the 2t oil switch through the fuel gauge, its all in 1 unit, very reasonable price too, considering all the usable functions. www.ebay.co.uk/itm/6-in-1-85MM-Tachometers-GAUGE-WATER-OIL-TEMP-PRESSURE-Voltmeter-GPS-12V-UK/401478665376
Post by JonW on Jan 21, 2020 0:12:16 GMT 1
The problem with the first one is that you'll need a seperate temp gauge.
The 6 in 1 is pretty cool. Interesting that it should work with OEM sensors. I'd be interested to try one out. All you'd need is a nice round sat nav screen for the other side and you'd have very usable modern instruments
Post by tony2stroke on Jan 21, 2020 0:52:23 GMT 1
Yup, agree about the 1st 1, but the 2nd 1 covers everything you could want with a nice round sat nav as you say.
I like it and you keep the original clock surround with idiot lights.
