Post by mellow on Oct 1, 2018 22:24:37 GMT 1
Evening men. Well i finally bought the LC I was thinking about getting. It has had 4 previous owners, been sorned since 1990 and is on an A plate. It is a 12A but the odd thing is it has MK2/3 EVERYTHING!! See, now I'm thinking it must be an early registered MK2 OR someone has done a hell of a lot of work. lIKE I SAY IT HAS EVERYTHING, THE YPVS Servo bracket on the frame the loom to run the servo & controller. The bad points are it has the most ghastly paint job, black with purple/red/gold/green speckles and the black on the tank has crazed, And the grab rail,bars,tope yoke,light bracket and z brackets have all been painted gold The good points are the paint has preserved the tank and the chrome on the grab rail & light bracket. I will get the grab rail & headlamp rechromed though as there is some slight pitting. The engine is also excellent. My intention is to polish up the alloy get rid of the gold and do a black YPVS paint job on it. So here she is..... As you can probably guess it was originally white. So far I have DEOX-C'd the inside of the tank to keep it nice. Cleaned the powervalve Stripped the paint off the grab rail & fitted the YPVS Control box Ghastly paint job. Next up I am going to paint strip the tank, fork lowers, headlamp bracket, Z brackets & top yoke. Then get some etch primer on the tank and start to polish the fork lowers. Here is a little video of the ride home the day I picked it up. Was flat low down but once it hit 7k it went like a rocket. Now has fully working YPVS and is much better That's about it for now
Post by raven13 on Oct 1, 2018 22:35:46 GMT 1
before you get rid of the gold check if the wheels are original gold, if so keep them as originals are hard to find
Post by mellow on Oct 1, 2018 22:42:24 GMT 1
I will leave the wheels gold, although i don't really like them, I have inquired about swapping them for a black pair with one of our helpful forum members
Post by donkeychomp on Oct 2, 2018 23:21:52 GMT 1
Always liked the looks of the 125LC. If you were 17 it was the pups nuts. Going to follow this one with interest.
Post by ozzy on Oct 4, 2018 12:58:09 GMT 1
Now then Melz, that looks a nice clean tidy easy project mostly and all there .ππ» I be peeping on it. π
Post by mellow on Oct 4, 2018 13:04:47 GMT 1
Cheers. All there now apart from proper carb. Has a tzr carb on it. Goes well now with working ypvsπ Started stripping forks last night so I can paint strip them with the tank & gold brackets this weekend π
Post by mellow on Oct 8, 2018 17:26:44 GMT 1
Small update. Been hard at it paint stripping/Polishing Forks stripped & ready for paint removal along with tank Paint Stripped Tank Etch Primed Tank Sprayed Gloss Black with UPOL Power Can Aerosol. I bought this paint because the etch primer of theirs that i use is awesome & the gloss black was supposed to give a "professional finish" with great paint delivery. Not impressed. Had to hold the can about 6" away from tank to get any decent coverage, it spat like buggery & dripped onto one spot while spraying. I won't buy that again. Luckily this is just a temporary measure to keep tank covered until i get the whole spray job done. I will flat it down and polish for now. And finally...... One polished fork lower That's all for now folks
Post by badger1 on Oct 8, 2018 18:58:05 GMT 1
Blimey that tank looks straight, no dents??
Post by mellow on Oct 8, 2018 19:13:48 GMT 1
Lol no or rotπ It has been sorned since 1990 & sat in the back of the shop since I can remember, so Not been out muchππ
Post by ozzy on Oct 9, 2018 13:09:01 GMT 1
Sweet polishing melz ππ»
Post by mellow on Oct 11, 2018 15:06:21 GMT 1
Small update. Had half a day off as had a dentist appointment so resprayed tank after flatting it down yesterday. It's better now but still not that glossy so will add another couple of coats when cans arrive I also paint stripped the rest of the ghastly gold paint off of the other few bits And that my friends is all for now
Post by mellow on Oct 21, 2018 13:09:26 GMT 1
Post by tsa on Oct 21, 2018 22:39:25 GMT 1
When I use rattle cans I always warm them in a bucket or hand hot (60*C) water for about 10 mins watching the can doesnt get to hot, while shaking the can every few mins and returning it to the bucket. Once warm the pressure is increased in the can and it tends not to spit.
Post by donkeychomp on Oct 21, 2018 22:43:12 GMT 1
Tank looks great!
Post by mellow on Nov 11, 2018 18:18:29 GMT 1
Post by ozzy on Nov 11, 2018 22:32:29 GMT 1
Looking good melz.ππ»
Post by veg on Nov 27, 2018 16:44:58 GMT 1
Stunning job always fancied one. Great to see it coming back together.
Post by mellow on Dec 23, 2018 15:49:21 GMT 1
Post by petenofear on Dec 23, 2018 21:42:52 GMT 1
what did you polish the forks with
I have been doing mine today flat back with 1500 then 2000 wet and dry ,taking hours but nearly there
Post by mellow on Dec 23, 2018 21:48:08 GMT 1
Gave them a light sand then used 3 grades of polishing soaps & mops on bench grinderπ
Post by mellow on Jan 15, 2019 23:15:35 GMT 1
Managed to source myself a 1GU Carb from greece. Wasn't any snow on it thankfully. But there was a whole load of tar like brown/black goo inside. The needle needed some pressure to push it out of the jet, the air screw was gummed in as was the float pin. I only really bought this for the internals but may use it depending what i find on the tzr carb currently in use. I have managed to strip the carb completely now, including removing the brass ball so next time i'm free it will be having a good scrub,spray with carb cleaner and a few cycles in the ultrasonic cleaner Amazingly the pilot jet and airways seem to be clear when spraying carb cleaner through.
Post by jon on Jan 16, 2019 19:10:08 GMT 1
Managed to source myself a 1GU Carb from greece. Wasn't any snow on it thankfully. But there was a whole load of tar like brown/black goo inside. The needle needed some pressure to push it out of the jet, the air screw was gummed in as was the float pin. I only really bought this for the internals but may use it depending what i find on the tzr carb currently in use. I have managed to strip the carb completely now, including removing the brass ball so next time i'm free it will be having a good scrub,spray with carb cleaner and a few cycles in the ultrasonic cleaner Amazingly the pilot jet and airways seem to be clear when spraying carb cleaner through. Mick, are you sure the advert said a carb from Greece, or a carb full of grease? Jon
Post by mellow on Jan 16, 2019 19:30:02 GMT 1
grease would have been better
Post by mellow on Jan 18, 2019 18:25:57 GMT 1
All done. Before After
Post by Mr Kipling on Jan 18, 2019 19:13:46 GMT 1
wow excellent job on the tank etc...
Post by mellow on Jan 18, 2019 19:43:00 GMT 1
Thanks. Getting proper full spray job next month π
Post by mellow on Jan 21, 2019 16:21:18 GMT 1
Took the carb off my bike that it was running. Apparently it was really clean from the guy i got bike off. It was boggy to pull away and the throttle and air screws seem to have had no effect. The emulsion tube was pretty much blocked as was the pilot. This is what was behind the ball It now starts first kick,picks up off idle well & idles nicely
Post by petenofear on Jan 21, 2019 18:24:04 GMT 1
Happy days
How did you get that ball out is it easy
Post by mellow on Jan 21, 2019 18:33:28 GMT 1
Yes incredibly, even I have managed on 2 carbsππ As in other threads have said centre punch ball, drill but not all the way through, screw in a self tapper, wiggle & pull outππ
Post by petenofear on Jan 21, 2019 19:22:29 GMT 1
So what do you replace with mate
