Post by tomitch on Mar 22, 2009 19:30:07 GMT 1
is there a throttle cable i can use instead of the std one because im not using the oil pump and thought since a single cable has no joints or splitters it should last a wee bit longer?? norbs have u got anything ??
Post by twostroker on Mar 22, 2009 20:42:06 GMT 1
cheapest and easiest way is to pull the "y splitter" apart and snip the part off for the oil pump off,clip the splitter bit back together and hey presto a cable with no oil pump cable,while its in bits id put a few drops of oil down the cable to lube it up,i converted my standard cable to run a pwk28 carb and no oil pump,bit like fitting a break cable on a push bike lol. you can buy a universal cable but you will have to trim the inner and outer cables to the correct lenth witch isnt hard but id just mod the standard one
Post by tomitch on Mar 22, 2009 22:11:12 GMT 1
iv done that aswell i keep all the old cables lol and make the odd decent one, that lasts me a while i was just interested to see if there were any single ones that i could fit.
Post by twostroker on Mar 22, 2009 22:27:48 GMT 1
iv done that aswell i keep all the old cables lol and make the odd decent one, that lasts me a while i was just interested to see if there were any single ones that i could fit. with a universal cable you will have to trim it to fit and solder/crimp the nipple end for either the carb end or the candle end so i would personaly mod a standard cable,imagine if the end comes loose on a universal cable 20 miles away from home. i remember when i was a lad we used to use push bike cables for throttle cables and for the nipple end that goes in either the twist grip or the carb slide we used to strip a old 240volt 3 pin plug and use the litte bits that the wires screw into,very rarley ever went wrong,
