Post by paulperth on Jul 11, 2018 15:54:26 GMT 1
Mine was seized up so I refurbished it and put it in a safe place until I needed it, buggered if I can find it have looked everywhere, does anyone know if an LC Speedo Drive or any other model will fit a 250E? I noticed that the dust seals where the same part number so I'm hoping the LC one will fit as I have a mate who has a spare.
Very frustrated - The joys of rebuilding old bikes
Paul
Post by reedpete on Jul 11, 2018 23:41:20 GMT 1
Don’t think so sadly, the LC has different part number for the bit you need even though some of the other parts are 2R8
Post by reedpete on Jul 11, 2018 23:42:28 GMT 1
It might fit but LC has 13 teeth so probably slightly diferent gearing
Post by muttsnuts on Jul 12, 2018 9:38:41 GMT 1
if you mean the part that fits in the front wheel then yes they fit, in regards are they the same ratio, I've no idea TBH, easiest way is to fit and check it
Post by reedpete on Jul 12, 2018 9:51:59 GMT 1
Thinking about it more the biggest problem is the wheel spindle. It might fit the wheel but not the spindle.
Post by muttsnuts on Jul 12, 2018 10:34:24 GMT 1
Thinking about it more the biggest problem is the wheel spindle. It might fit the wheel but not the spindle. aye, that's a good poingt, think they are different sizes, that would cause an issue, although the LC one is thinner, so could easily be fixed by boring it out to the right size
Post by paulperth on Jul 13, 2018 12:05:40 GMT 1
Mates dropping it off this weekend so I'll keep you all posted.
Thank you for your help
Paul
